- Thank you received: 27
Sometimes my tool unload code just…stops
- JetForMe
- Topic Author
5 years 11 months ago #190923
by JetForMe
Sometimes my tool unload code just…stops was created by JetForMe
Not sure if this is the right category for this question, but I'm having an issue with my tool unload routine (attached). In response to T0M6, it positions the spindle in front of the tool fork, and is supposed to move downward to the fork level with G1, but it just…doesn't move. I have to click the STOP button in Axis, and then issue the T0M6 again, and then it continues without issue.
Any idea why it's stopping? I put a bunch of print statements in the code, and it prints `Unload tool: Lowering F1000`, but doesn't do anything more. Axis seems to think it's still running a program though, since I have to click the stop button.
- chris@cnc
- Thank you received: 140
5 years 10 months ago #191174
by chris@cnc
Replied by chris@cnc on topic Sometimes my tool unload code just…stops
My experience with variable programming is that sometimes the variables have logically different values than you think. At first glance, I would trigger the feed variable.
Maybe start with this sentence ..
G53 G1 F #<_ini[atc]speed_approach> Z #<_ini[atc]z_pocket>
- JetForMe
- Topic Author
5 years 10 months ago #191188
by JetForMe
Replied by JetForMe on topic Sometimes my tool unload code just…stops
Yeah, I print out the speed before that line. It prints:
Unload tool: Lowering F5000.0
- Thank you received: 2181
5 years 10 months ago #191202
Replied by cmorley on topic Sometimes my tool unload code just…stops
Is this part of remap code?
- JetForMe
- Topic Author
5 years 10 months ago #191206
by JetForMe
Yes, in the sense that I remap M6 to invoke it.
github.com/JetForMe/router-table/blob/ma...auto_tool_change.ngc
github.com/JetForMe/router-table/blob/ma...c_subroutines/ut.ngc
REMAP= M6 modalgroup=6 prolog=change_prolog ngc=auto_tool_change epilog=change_epilog
- JetForMe
- Topic Author
2 years 4 months ago #302453
by JetForMe
This still happens to me, and it's happening with a new program I'm trying to write to vacuum the table (unload the tool, lower the spindle, move the dust collector shoe over the whole table).
I invoke it from a button in my Axis VCP, but it frequently stops mid-move. Is there some line I need to add to my subroutine to make it wait for the move to complete?
It will randomly stop on the G1 Z down move, or the G1 X move. Always seems to successfully raise the spindle and move to the start position.
My ngc is attached.
My ngc is attached.
- Thank you received: 2177
2 years 4 months ago #302463
Replied by Aciera on topic Sometimes my tool unload code just…stops
Can be tricky troubleshooting these things. Usually I liberally insert queuebusters (eg 'M66 L0 E0') to avoid premature ingestion of code lines by the read ahead.
Maybe try that right after 'G53 G1 X1245'
It may also help to insert debug printing like this (this will print to terminal):
;(print, your_parameter=#<your_parameter>)
Or this will print to the gui:
;(msg, your_parameter=#<your_parameter>)
This will give you an indication of where the execution actually fails.
- MaHa
- Thank you received: 241
2 years 4 months ago #302469
by MaHa
Replied by MaHa on topic Sometimes my tool unload code just…stops
On my machine, spindle.0.at-speed must be true to do a move with G1
- JetForMe
- Topic Author
2 years 4 months ago - 2 years 4 months ago #302917
by JetForMe
I've got a print statement at the end of the Python routine that still gets called, even though the motion stops.
This would result in it not moving at all, but it moves an inconsistent amount and then stops.
Last edit: 2 years 4 months ago by JetForMe.
- JetForMe
- Topic Author
2 years 2 months ago #309232
by JetForMe
The answer was given to me in another post, and it is to pass a longer timeout to the Python function wait_complete(), which, when passed nothing, defaults to 5 seconds.
