NPT thread milling
4 years 11 months ago #226024 by papagno-source
Hi at all.
Exist some example for realize the NTP conical thread on milling ?
4 years 11 months ago - 4 years 11 months ago #226028 by MaHa
Replied by MaHa on topic NPT thread milling
Linuxcnc makes some problems sometimes with cuttercompensation, maybe you can make this run.
;G1/2-NPT P=1.814 N1605 G0 G94 X0 Y0 F1000 S860 M3 N1610 M8 N1615 Z100. N1620 G94 G64 P0.005 N1625 G0 Z3. N1630 G1 G91 Z=-17.38 F1000 N1635 Y1.450 F40 N1640 G41 X8.735 N1645 G3 X-8.735 Y8.735 I-8.735 J0. N1650 X-10.199 Y-10.185 I-0.007 J-10.192 Z0.454 N1655 X10.199 Y-10.213 I10.206 J-0.007 Z0.454 N1660 X10.228 Y10.213 I0.007 J10.220 Z0.454 N1665 X-10.228 Y10.242 I-10.235 J0.007 Z0.454 N1670 X-8.735 Y-8.735 I0. J-8.735 F140 N1675 G1 G40 X8.735 Y-1.450 N1680 G90 G1 Z3. F3000 N1685 G0 Z500. M9
Last edit: 4 years 11 months ago by MaHa.
4 years 11 months ago #226035 by papagno-source
Replied by papagno-source on topic NPT thread milling
Thanks.
This not are parametri macro for NTP thread.
Normally will specified more parametric for differet type the NTP.
example fanuc have :
g65 p9063 D50 A10 R5 z-18.55 i-1.84 w0 f250.
This is macro fanuc for continuos threading do initial diameter , angle the conical thread, z finish working ecc.
Existe some example for parametric macro ?
4 years 11 months ago #226549 by papagno-source
I stay convert for linuxcnc a Fanuc macro.
When finish and testing it, i will attachment the code and use for it .
Thanks for support
Time to create page: 0.247 seconds
