Call O Codes from hal signal
  • Pro_El
  • Pro_El's Avatar Topic Author
  • Premium Member
  • Premium Member
05 Dec 2021 11:12 #228391 by Pro_El
Call O Codes from hal signal was created by Pro_El
I am starting to learn for subroutines. I finished one mill tool-change with Ladder. My next project is tool-change with axis movement positions. I think subs will be the best choise, fix me if i am wrong.  i cannot find some very obvious staff..
My first question will be can i start subroutines with signal from Hall in Auto mode
Thanks a lot
05 Dec 2021 12:24 #228399 by anfänger
Replied by anfänger on topic Call O Codes from hal signal
Yes you can take a look at
HALUI:
halui.mdi-command-XX bit in
halui looks for ini variables named [HALUI]MDI_COMMAND, and exports a pin for each command it finds. When the pin is driven TRUE, halui runs the specified MDI command. XX is a two digit number starting at 00. If no [HALUI]MDI_COMMAND variables are set in the ini file, no halui.mdi-command-XX pins will be exported by halui.
You might need to remap your O Word to a user Code first. But after this it's no probem
linuxcnc.org/docs/html/config/ini-config...l#gcode:ini-features
linuxcnc.org/docs/html/man/man1/halui.1.html
linuxcnc.org/docs/html/remap/remap.html
Cheers
Patrick
The following user(s) said Thank You: Pro_El, zz912
  • Pro_El
  • Premium Member
  • Premium Member
05 Dec 2021 15:42 #228406 by Pro_El
Replied by Pro_El on topic Call O Codes from hal signal
Great start for me, I will make this on machine and test it how is working
Thanks again anfänger
20 Mar 2023 08:41 #267148 by zz912
Replied by zz912 on topic Call O Codes from hal signal
Exist some specification of halui.mdi-command-XX ?
Or exmaple?
In INI file:
[HALUI]
MDI_COMMAND
or
[HALUI]
MDI_COMMAND.ngc
In config folders must be file:
MDI_COMMAND.ngc
Can / must be it in some subfolder.
The *.ngc file must contain M2?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
20 Mar 2023 10:30 #267154 by andypugh
Replied by andypugh on topic Call O Codes from hal signal
There are some examples here: github.com/LinuxCNC/linuxcnc/blob/master...hb04/layout1.inc#L32
I think that, for example:
MDI_COMMAND = O<my_subroutine> CALL
should work
The following user(s) said Thank You: zz912
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
20 Mar 2023 10:30 #267155 by andypugh
should work
20 Mar 2023 10:47 #267159 by zz912
Thank you.
MDI_COMMAND=(debug, example: mdi-01)
What "debug" command mean?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
20 Mar 2023 11:12 #267162 by andypugh
It's a "magic comment"
linuxcnc.org/docs/stable/html/gcode/over....html#gcode:comments
Listed elsewhere, there is also:
(ABORT, ...) Which stops execution with a message and (py, ...) which will execute python code. (and also (pyrun, ) and (pyreload, ). I don;t know what the last two do.
Time to create page: 0.989 seconds
