use ini parameters in own subroutine
- mgm
- Thank you received: 13
26 May 2022 15:55 - 27 May 2022 06:08 #243912
by mgm
use ini parameters in own subroutine was created by mgm
hello guys
I want to store some parameters in the ini and then use them in my subroutine.
I am doing something wrong!
I have entered the following in the ini:
[GCODE_MIRROW]
x = 2486.3
the subroutine is:
[/code][/code][/code][/code]
[GCODE_MIRROW]
x = 2486.3
the subroutine is:
[code][code][code]o<tool_move> sub
o100 if [EXISTS[#<_ini[gcode_mirrow]x>]]
(debug, #<_ini[gcode_mirrow]x>;)
o100 else
(debug, not available)
o100 endif
o<tool_move> endsub
m2
[code]When I now call the program I get not "x=10" but "not available".
where is the problem?
I try this in an axis sim 2.8.2
Last edit: 27 May 2022 06:08 by mgm.
- robertspark
- Thank you received: 216
26 May 2022 15:57 - 26 May 2022 16:04 #243914
by robertspark
Replied by robertspark on topic use ini parameters in own subroutine
oops:
linuxcnc.org/docs/2.9/html/gcode/overvie...gcode:ini-hal-params
its not case sensitive.
what about removing the semi-colon ";"
[/b] (debug, #<_ini[gcode_mirrow]x>;)
Last edit: 26 May 2022 16:04 by robertspark.
- mgm
26 May 2022 16:15 #243918
by mgm
Replied by mgm on topic use ini parameters in own subroutine
oh yes thanks I overlooked
have now added the following to the ini so that the :
INI_VARS = 1 Default 1 Allows G-code programs to read values from the INI file using the format #<_ini[section]name>.
unfortunately no success!
- roland
- Thank you received: 64
26 May 2022 19:13 #243938
by roland
Replied by roland on topic use ini parameters in own subroutine
try a uppercase X in your ini.
btw: the closing round bracket is missing in your first debug line
- mgm
26 May 2022 19:32 #243941
by mgm
Thank you so much, you made my day!
The solution was perfect, within the ini you need a capital X.
Time to create page: 0.189 seconds
