Switching HAL pin in subroutine (macro)
- JuFu
21 Feb 2025 10:16 #322190
by JuFu
Switching HAL pin in subroutine (macro) was created by JuFu
I want to set / reset a HAL pin by using G-codes (switching a pneumatic valve on/off).
In the documentation G-code Overview | 4. HAL pins and INI values is written: " ... the only way to set HAL pins from G-code remains M62-M65, M67, M68 and custom M100-M199 codes."
I wrote the below subroutine (macro):
o<test> sub
(MSG, Spannzange öffnen)
M62 #<_hal[hm2_7i76e.0.7i76.0.0.output-00]
o<test> endsub
M2
When I run the macro, the response is: "Benannter Parameter nicht beendet"
(Using gmoccapy Ver 3.4.9 in German language)
Is there a better way to control HAL pins?
If not, what do I need to do?
Juergen
o<test> sub
o<test> endsub
M2
Juergen
- JuFu
21 Feb 2025 10:50 #322193
by JuFu
Replied by JuFu on topic Switching HAL pin in subroutine (macro)
Issue solved by using M100
- Soccer Kid
- Thank you received: 7
14 Apr 2025 07:09 #326249
by Soccer Kid
Replied by Soccer Kid on topic Switching HAL pin in subroutine (macro)
You should use the M100 to call python programs to do this, see the following example.......linuxcnc.org/docs/stable/html/gcode/m-code.html#mcode:m100-m199.
Time to create page: 0.109 seconds
