- GCode and Part Programs
- O Codes (subroutines) and NGCGUI
- Having issues with oword test scripts in version 2.9.4
- scsmith1451
- Thank you received: 3
06 Sep 2025 16:09 #334562
by scsmith1451
Having issues with oword test scripts in version 2.9.4 was created by scsmith1451
All;
I'm running LCNC 2.9.4 upgraded from a 2.9.3 disc image install.
I have this simple test script:
o<mytest2> sub
#<factor> = 1
o100 if [#<_metric>]
#<factor> = 25.4
o100 endif
#<value> = 30 * #<factor>
(LOGOPEN,mytest.txt)
(LOG, factor: #<factor>)
(LOG, value: #<value>)
(LOGCLOSE)
o<mytest2> endsub
in my nc_files directory. If I comment out the two lines with "value" in then the script runs fine in both sim.axis and sim.axis_mm profiles. When I uncomment the lines I get this output:
emc/task/emctask.cc 68: interp_error: Bad character '*' used
According to the documentation "*" is the multiplication operator. Anyone else experiencing this issue? Is there a resolution?
The second issue is closely related.
I also have this test script:
o<mytest2> sub
#<factor> = 1
#<factor> = 25.4
o100 endif
(LOG, laser-offset-x: #<_ini[LASER]laser-offset-x>)
(LOG, laser-offset-y: #<_ini[LASER]laser-offset-y>)
(LOG, park-offset: #<_ini[PARK]park-offset>)
(LOG, z-offset: #<_ini[PROBE]z-offset>)
(LOGCLOSE)
o<mytest2> endsub
where I try to read ini parameters defined in the axis.ini and axis_mm.ini files as follows:
[LASER]
laser-offset-x = -3.1702
laser-offset-y = 0.0568
[PARK]
park-offset = 0.125
[PROBE]
z-offset = 0.543
When the script is executed the output looks like this:
LOGOPEN(mytest.txt) -> 0x55cc4c8cee20
LOG( laser-offset-x: ######)
LOG( laser-offset-y: ######)
LOG( park-offset: ######)
LOG( z-offset: ######)
LOGCLOSE()
Again, is anyone else experiencing this issue in 2.9.4? Is there a resolution?
Kind regards
o<mytest2> sub
#<factor> = 1
#<factor> = 25.4
o100 endif
(LOGCLOSE)
o<mytest2> endsub
o<mytest2> sub
#<factor> = 1
#<factor> = 25.4
o100 endif
(LOGCLOSE)
o<mytest2> endsub
[LASER]
[PARK]
park-offset = 0.125
[PROBE]
z-offset = 0.543
LOGCLOSE()
Kind regards
- Hakan
- Thank you received: 477
06 Sep 2025 16:23 - 06 Sep 2025 16:23 #334564
by Hakan
Replied by Hakan on topic Having issues with oword test scripts in version 2.9.4
There is a difference versus the doc linuxcnc.org/docs/html/gcode/o-code.html#ocode:subroutines
Use o100-style instead of o<mytest2>?
o100 sub
g-code
o100 endsub
o100 sub
g-code
o100 endsub
Last edit: 06 Sep 2025 16:23 by Hakan.
- MaHa
- Thank you received: 241
06 Sep 2025 16:23 #334565
by MaHa
Replied by MaHa on topic Having issues with oword test scripts in version 2.9.4
I think there are square brackets required
#<value> = [30 * #<factor>]
setting to read values from ini file
[RS274NGC]
INI_VARS = 1
[RS274NGC]
INI_VARS = 1
- scsmith1451
09 Sep 2025 06:34 #334683
by scsmith1451
Replied by scsmith1451 on topic Having issues with oword test scripts in version 2.9.4
Thanks MaHa,
The bracket syntax worked great, however, I'm still not able to access the INI vars after adding the INI_VARS = 1 to the ini file. Is there another setting that I'm missing?
- MaHa
11 Sep 2025 13:38 #334838
by MaHa
Just in case it's not solved yet:
Use capital letters for ini file entrys...
[LASER]
LASER-OFFSET-X = -3.1702
LASER-OFFSET-Y = 0.0568
[PARK]
PARK-OFFSET = 0.125
[PROBE]
Z-OFFSET = 0.543
The following user(s) said Thank You: scsmith1451
Time to create page: 0.464 seconds
