Help - Can't see the forest for the trees!
  • scsmith1451
  • scsmith1451's Avatar Topic Author
  • Premium Member
  • Premium Member
13 Sep 2025 19:21 #334941 by scsmith1451
Help - Can't see the forest for the trees! was created by scsmith1451
When I try to execute the attached macro from MDI in GMOCCAPY or AXIS I get the error:
Bad character '<'
Can't find anything incorrect in the file which I have attached. I went so far as to comment out all of the lines and just tried to open a LOG file to see where the error might be, but the error occurs before the file is opened.
An extra pair of eyes would be most appreciated.
Kind Regards,
13 Sep 2025 19:57 - 13 Sep 2025 19:58 #334942 by tommylight
Replied by tommylight on topic Help - Can't see the forest for the trees!
Well, something is not right, i can not see the attached file, but if i choose to quote your message, it shows up!
Fro your file (as i have no clue if this is the issue)
<#factor> = 1 (Adjust for metric)
Probably should be
#<factor> = 1 (Adjust for metric)
Last edit: 13 Sep 2025 19:58 by tommylight. Reason: more info
  • scsmith1451
  • Premium Member
  • Premium Member
14 Sep 2025 17:39 #334986 by scsmith1451
Replied by scsmith1451 on topic Help - Can't see the forest for the trees!
Don't know why file didn't come through, but I'm pasting it here:
o<auto-xy-zero> sub
o100 if [#<_metric> EQ 1]
#<factor> = 25.4
o100 endif
#<X-move> = [#<_ini[LASER]laser-offset-x> * #<factor>]
#<Y-move> = [#<_ini[LASER]laser-offset-y> * #<factor>]
#<feedrate> = [20 * #<factor>]
; (Move table to program start)
G91 G0 X#<X-move> Y#<Y-move> F#<feedrate>
G10 L20 P0 X0 Y0 A0 ( Set X/Y DROs to zero )
o<auto-xy-zero> endsub
m2
Looks to me that all of the references are correctly formatted.
Regards,
14 Sep 2025 18:07 #334989 by tommylight
Second line does not look correct, see my previous post.
You have a # in the wrong place behind a < , it should be in front of it.
The following user(s) said Thank You: scsmith1451
