calling subroutine from G54, G55, G56, but it acts weird
10 months 5 days ago #340557 by MaHa
I was just working on a mdi command, so it was easy to have a look at this in FlexGui.
Starting with  G0G55X0Y0
Then pressing the button with MDI command
and it goes to    G0G54X0Y0
the subroutine:
o<work_zero> sub
G90 G54 G0 X0 Y0
o<work_zero> endsub [1]
M2
10 months 5 days ago #340559 by tlightus
thank you for testing. i have been getting a very different result but will go back and see if it was something i was doing wrong.
10 months 5 days ago #340586 by tlightus
i did notice you use machine zero as the G54 offset. try setting it off that and run the test.
10 months 5 days ago #340595 by MaHa
Today i tested with axis, made an entry in ini:
[HALUI]
MDI_COMMAND = O<work_zero> call
and had this button in glade in postgui.hal
net tb  gladevcp.tb.tog halui.mdi-command-00
The subroutine as before, and the result as before. MDI G0G55X0Y0, when press the button it moves to G0G54X0Y0
Time to create page: 0.254 seconds
