Embedding ngcgui in EMC 2.4.x
- BigJohnT
- Thank you received: 994
30 Mar 2011 13:36 - 05 Jun 2011 20:55 #8285
by BigJohnT
Embedding ngcgui in EMC 2.4.x was created by BigJohnT
This is a short step by step to install Dewey Garretts ngcgui into Axis assuming you have EMC2 2.4 installed on Ubuntu 8.04 and not a RIP.
Open up a terminal and type the following commands
cd emc2
mkdir ngcgui
cd ngcgui
wget gnipsel.com/shop/emc2/ngcgui/ngcgui.tgz
or
wget www.panix.com/~dgarrett/ngcgui/ngcgui.tgz
tar zxf ngcgui.tgz
sudo apt-get install libtk-img
Now you have the files located in ~emc2/ngcgui/t\ngcgui_tst directory and can close the terminal window.
Using the file browser copy the following files to your config directory (the same directory as your ini file)
tkapp.py (2.4 only)
ngcgui_app.tcl
ngcgui.tcl
ngcgui_ttt.tcl
Now copy the following files from the testsuite directory to the emc2/nc_files directory.
gosper.ngc
hw.ngc
ihex.ngc
in_std.ngc
iquad.ngc
line.ngc
move.ngc
simp.ngc
spin.ngc
slot.ngc
xyz.ngc
Now open your ini file and add the following to the [DISPLAY] section.
Make sure you replace username with your username.
USER_COMMAND_FILE = tkapp.py
TKAPP = ngcgui_app.tcl
NGCGUI = ngcgui.tcl
NGCGUI_FONT = Courier -10 normal
NGCGUI_PREAMBLE = /home/username/emc2/nc_files/in_std.ngc
NGCGUI_SUBFILE = /home/username/emc2/nc_files/slot.ngc
NGCGUI_SUBFILE = /home/username/emc2/nc_files/simp.ngc
NGCGUI_SUBFILE = /home/username/emc2/nc_files/iquad.ngc
NGCGUI_SUBFILE = /home/username/emc2/nc_files/gosper.ngc
NGCGUI_OPTIONS = nonew noremove nonew
This should get you up and going with embedded ngcgui.
Thanks Dewey!
Enjoy
cd emc2
mkdir ngcgui
cd ngcgui
or
tar zxf ngcgui.tgz
tkapp.py (2.4 only)
ngcgui_app.tcl
ngcgui.tcl
ngcgui_ttt.tcl
gosper.ngc
hw.ngc
ihex.ngc
in_std.ngc
iquad.ngc
line.ngc
move.ngc
simp.ngc
spin.ngc
slot.ngc
xyz.ngc
NGCGUI = ngcgui.tcl
Thanks Dewey!
Enjoy
Last edit: 05 Jun 2011 20:55 by BigJohnT.
- BigJohnT
31 Mar 2011 10:43 - 05 Jun 2011 19:49 #8318
by BigJohnT
Replied by BigJohnT on topic Re:Embedding ngcgui in EMC 2.4.x
To use ngcgui go to a tab and fill in the blanks with the proper values. Click on Create Feature then click on Finalize. The ngcgui program will build the file by adding the preamble, the subroutine and then tack a M2 on the end to finish off the g code.
The real power comes when you have more than one step you need to do. Just go to each tab and fill in the blanks and click on Create Feature but don't click on Finalize until you have all the features built. You can change the order of the features before clicking on Finalize.
Last edit: 05 Jun 2011 19:49 by BigJohnT.
- cncbasher
- Thank you received: 202
31 Mar 2011 10:55 #8320
by cncbasher
Replied by cncbasher on topic Re:Embedding ngcgui in EMC 2.4.x
thanks John
error file attached
running 2.4.6
ubunto 10.04 install live cd
error file attached
running 2.4.6
Attachment error-c685e1f2378b11930c4a1376a1d75c44.txt not found
- BigJohnT
31 Mar 2011 10:59 #8321
by BigJohnT
My guess is it is this line from the error
Starting EMC2 DISPLAY program: ./tkapp.py
Shutting down and cleaning up EMC2...
if tkapp.py is in the same directory as your config remove the ./ from it and it should work.
- cncbasher
31 Mar 2011 11:12 #8323
by cncbasher
attached new error log
remove ngcgui from ini and emc runs fine
Attachment error2.txt not found
- BigJohnT
31 Mar 2011 11:13 #8324
by BigJohnT
Attach your ini file so I can look at it.
- cncbasher
31 Mar 2011 11:19 #8325
by cncbasher
here you go John
Attachment my_lathe.ini not found
- BigJohnT
31 Mar 2011 11:22 - 31 Mar 2011 11:23 #8327
by BigJohnT
Your DISPLAY needs to remain unchanged and point to AXIS.
DISPLAY = axis
DISPLAY = axis
Last edit: 31 Mar 2011 11:23 by BigJohnT.
- cncbasher
31 Mar 2011 11:28 #8328
by cncbasher
Duh ! , thanks John much appriciated
now to figure how to use it
Dave
Dave
- BigJohnT
31 Mar 2011 11:30 #8329
by BigJohnT
Cool!
What kind of lathe do you have?
There are a bunch of lathe subroutines here to try out.
If you have any questions just start a new topic on it here.
Time to create page: 0.270 seconds
