Embedding ngcgui in EMC 2.4.x
- Rick G
- Thank you received: 114
Thats great, good to have all the info here in one place on the forum.
Should...
NGCGUI_SUBFILE = ""
be added to the list of subfiles to add the custom tab?
NGCGUI_SUBFILE = ""Now open your ini file and add the following to the [DISPLAY] section.
USER_COMMAND_FILE = tkapp.py
TKAPP = ngcgui_app.tcl
NGCGUI = ngcgui.tcl
NGCGUI_FONT = Courier -10 normal
NGCGUI_PREAMBLE = ./subroutines/in_std.ngc
NGCGUI_SUBFILE = ./subroutines/simp.ngc
NGCGUI_SUBFILE = ./subroutines/iquad.ngc
NGCGUI_SUBFILE = ./subroutines/gosper.ngc
Rick G
- BigJohnT
- Thank you received: 994
It can be if you want it. I was just trying to get the minimal up and going but that is a good addition even if I don't know exactly what it does ATM.
- Rick G
Special location for files?
Rick G
- BigJohnT
I use a desktop shortcut to run 2.5 with ngcgui embedded in. I do it a couple of ways, one using a script to run emc-environment and the other way is just to put the full path to the RIP emc script then the full path to your config.
- Rick G
That seems to work best for me.one using a script to run emc-environment
Rick G
- swtswt
- Visitor
I want to ask where is the file "tkapp.py" ?
Because I've downloaded ngcgui_tst and can't find that file
Thanks..
- Rick G
Rick G
- submicro
- Rick G
You might want to look here...
www.panix.com/~dgarrett/ngcgui/readme
If you are upgrading from 2.4 there are some changes.
You can run it stand alone or embedded.
Rick G
- submicro
