Embedding ngcgui in EMC 2.4.x
14 years 6 months ago #19431 by Rick G
Yep.
You might want to look here...
www.panix.com/~dgarrett/ngcgui/readme
If you are upgrading from 2.4 there are some changes.
You can run it stand alone or embedded.
Rick G
14 years 6 months ago #19445 by submicro
I've tried getting to work but have been unsuccessful.
14 years 6 months ago #19446 by submicro
I get this error when I start LinuxCNC.
"<simp.ngc> must be in search path
Current Directory: /home/submicro/linuxcnc/configs/MiniMill_inch
Search Path:
../../../nc_files
../../../nc_files/ngcgui_lib
../../../nc_files/ngcgui_lib/utilitysubs
Checking for:
[RS274NGC]SUBROUTINE_PATH in ini file:
/home/submicro/linuxcnc/configs/MiniMill_inch/MiniMill.ini
Restart after fixing file"
Help appreciated
SubMicro
14 years 6 months ago - 14 years 6 months ago #19454 by Rick G
Looks like you need to change the location of the sub files or the search path to them.
This may help...
linuxcnc.org/docs/html/gui/ngcgui.html
I often put mine in nc_files
Rick G
Last edit: 14 years 6 months ago by Rick G.
14 years 6 months ago #19472 by submicro
That link is what I followed trying to get it working. I'm using 10.04 with linuxcnc2.5 The sim works but, getting it working with my actual setup has proved difficult. In my ini file I used relative paths i.e.
SUBROUTINE_PATH = ../../../nc_files/ngcgui_lib:../../../nc_files/ngcgui_lib/utilitysubs
USER_M_PATH = ../../../nc_files/ngcgui_lib/mfiles
The file it's looking for are in those paths. I checked.
SubMicro
14 years 6 months ago #19473 by BigJohnT
Some of the sample subroutines rely on other subroutines so you have to have them all in the correct place. Comment out all of the subroutines except a simple one and see if you can get the syntax correct. I just use the actual full path to mine... attach your ini file for us to look at.
Time to create page: 0.409 seconds
