NGCGUI not working after emc2 update
- kb8wmc
- Thank you received: 4
The following is a copy of the present ini file...
Thanks for your input John
# Generated by stepconf at Sat Mar 12 02:32:11 2011
# Changes to this file WILL BE
# overwritten when you run stepconf again
[EMC]
MACHINE = router
DEBUG = 0
# DISPLAY OPTIONS SECTION
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 2
PROGRAM_PREFIX = /home/mike/emc2/configs/router
PROGRAM_PREFIX = /home/mike/emc2/testsuite2.5
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
PYVCP = custompanel.xml
#EMBED_TAB_NAME = CAM_View
#EMBED_TAB_COMMAND = camview-emc -C camviewcfg -g togle.ui -H campins.hal -w {XID}
#EMBED_TAB_NAME = Camera
#EMBED_TAB_COMMAND = camview-emc -w {XID}
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
# NGCGUI ADDON
TKAPP = /home/mike/emc2/ngcgui_app.tcl
TKAPP = /home/mike/emc2/ngcgui_ttt.tcl
TKAPP = /home/mike/emc2/testsuite2.5/calc.tcl
NGCGUI = /home/mike/emc2/ngcgui.tcl
NGCGUI_FONT = Helvetica -10 bold
NGCGUI_PREAMBLE = /home/mike/emc2/testsuite2.5/utilitysubs/in_std.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/xyz.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/iquad.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/ihex.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/ohex.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/gosper.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/hw.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/hole_circle.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/slot.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/simp.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/millmultiple.ngc
NGCGUI_SUBFILE = /home/mike/emc2/testsuite2.5/501.ngc
TTT = /usr/bin/truetype-tracer
# TASK CONTROLLER SECTION
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
# PART PROGRAM INTERPRETER SECTION
[RS274NGC]
PARAMETER_FILE = emc.var
#PARAMETER_FILE = ngcgui.var
SUBROUTINE_PATH = /home/mike/emc2/testsuite2.5:/home/mike/emc2/testsuite2.5/utilitysubs
USER_M_PATH = /home/mike/emc2/testsuite2.5/mfiles
# MOTION CONTROL SECTION
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
# HARDWARE ABSTRACTION LAYER SECTION
[HAL]
HALUI = halui
HALFILE = router.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
# AUTO-Z TOUCH OFF
MDI_COMMAND = G38.2 Z-2 F5
MDI_COMMAND = G10 L20 P1 Z0.095
MDI_COMMAND = G0 Z0.75
MDI_COMMAND = G92 x2 y-.75
# CAMERA
#MDI_COMMAND=o<_camon>call
#MDI_COMMAND=o<_camoff>call
#MDI_COMMAND=o<_camstore>call
#MDI_COMMAND=o<_camcenter3>call
#MDI_COMMAND=o<_camcenter4>call
# TRAJECTORY PLANNER SECTION
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.00
MAX_LINEAR_VELOCITY = 10.00
# POSITION_FILE = position.txt
# MAIN IO CONTROLLER PARAMETER SECTION
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# AXES SECTIONS
[AXIS_0]
TYPE = LINEAR
HOME = 0.50
MAX_VELOCITY = 2.50
MAX_ACCELERATION = 20.0
STEPGEN_MAXACCEL = 25.0
SCALE = 888.875
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = 0.0
MAX_LIMIT = 96.0
HOME_OFFSET = -0.50
HOME_SEARCH_VEL = -0.50
HOME_LATCH_VEL = 0.562
HOME_FINAL_VEL = 1.00
HOME_SEQUENCE = 1
[AXIS_1]
TYPE = LINEAR
HOME = 0.50
MAX_VELOCITY = 2.50
SCALE = 888.875
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = 0.0
MAX_LIMIT = 48.0
HOME_OFFSET = -0.50
HOME_LATCH_VEL = -0.35
HOME_SEQUENCE = 2
[AXIS_2]
TYPE = LINEAR
HOME = -0.50
MAX_VELOCITY = 1.0
SCALE = 3980.0
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -6.125
MAX_LIMIT = 0.50
HOME_OFFSET = 0.50
HOME_SEARCH_VEL = 0.50
HOME_LATCH_VEL = 0.3125
HOME_SEQUENCE = 0
- BigJohnT
- Thank you received: 994
EMBED_TAB_NAME = term
EMBED_TAB_COMMAND = xterm -fa console-terminus -fs 8 -geo 120x24 -sb -into {XID} -hold -e date;echo;pwd;echo;ls;echo;bash
TKAPP = ./ngcgui_app.tcl
TKAPP = ./ngcgui_ttt.tcl
TKAPP = ./calc.tcl
NGCGUI = ./ngcgui.tcl
NGCGUI_FONT = Helvetica -12 normal
NGCGUI_PREAMBLE = /home/john/emc2/subroutines/std.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/face.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/od.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/id.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/part.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/drill.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/tap.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/th-od.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/taper-od.ngc
NGCGUI_SUBFILE = /home/john/emc2/subroutines/profilerad.ngc
NGCGUI_SUBFILE = ""
DISPLAY = axis
...Oh, that line EMBED_TAB_COMMAND is one long line...
- kb8wmc
Thanks for posting your example....I originally followed instructions from another of your earlier posts and created a subroutine directory and placed the .ngc files within it...pointed the .ini to that subdirectory to no avail...That subdirectory still exists, I changed my ini to point to it again and edited the other appropriate files and copied the .tcl files to ~/emc2 as well as left them in the .configs subdirectory...This is still not seeing these files and subdirectories...I am stumped...Below is a copy of the pertinent Display section...
# NGCGUI ADDON
TKAPP = ./calc.tcl
NGCGUI_PREAMBLE = /home/mike/emc2/subroutines/utilitysubs/in_std.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/xyz.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/iquad.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/ihex.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/ohex.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/gosper.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/hw.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/hole_circle.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/slot.ngc
NGCGUI_SUBFILE = /home/mike/emc2/subroutines/simp.ngc
NGCGUI_SUBFILE = /home/mike/emc2/configs/millmultiple.ngc
NGCGUI_SUBFILE = /home/mike/emc2/configs/501.ngc
[RS274NGC]
SUBROUTINE_PATH = /home/mike/emc2/subroutines:/home/mike/emc2/subroutines/utilitysubs
USER_M_PATH = /home/mike/emc2/subroutines/mfiles
Unfortunately, nothing I have tried, and I have tried everything I can think of for last two days seems to work...
Thanks again John
Mike
- BigJohnT
Oh I see you used synaptic...
If you comment out all the ngcgui parts does Axis load and show you 2.5 on the title bar?
- kb8wmc
How did you upgrade to 2.5?
John,
Yes sir, it does show 2.5 on the title bar...
What are your thoughts?
Mike
- BigJohnT
- kb8wmc
I added the following from the 2.4 instructions:
USER_COMMAND_FILE = ./tkapp.py
No Joy....Axis did not break either...
Right now I am wondering if it might be better to un-install emc2 then reinstall...
Mike
- BigJohnT
- kb8wmc
copied .tkapp.py into the config directory....no joy again....I don't know if it is interesting or not, but nothing I have done has borked Axis...it just seems to always start...
Mike
- BigJohnT
Like
net my bad error that will never run
