Gscreen - a GTK / Glade / Python based screen
- karlkec
13 years 10 months ago #27207
by karlkec
Replied by karlkec on topic Gscreen - a GTK / Glade / Python based screen
All,
I want to start playing with Gscreen on a touchscreen, using a computer I use for testing and debugging Gcode. Eventually hope to use it on a knee mill. Currently, I mostly use Touchy and sometimes Axis.
I have Linuxcnc 2.5 already installed on the test computer, and plan to set up a different partition to build and use Gscreen. Is it better to install Linuxcnc from the live CD to the new partition, or install Ubuntu 10.04 and then install LInuxcnc?
Karl
Karl
- Thank you received: 2181
13 years 10 months ago #27223
Replied by cmorley on topic Gscreen - a GTK / Glade / Python based screen
I would install 10.04 then use buildbot to get master (Gscreen requires master)
Others may have more experience with the easiest way to get it downloaded and updated.
Chris
Chris
- karlkec
13 years 10 months ago #27230
by karlkec
Chris,
Thanks for the advice. Using the buildbot sounds like a good way. Unfortunately I didn't see your message until I was into it a ways.
I installed 10.04, used the linuxcnc install script, grabbed master via git, and it all built just fine. Now to work on configuration.
Karl
Karl
13 years 10 months ago #27240
There are sample configs under sim/gscreen and sim/gscreen_custom.
And info on the wiki and of course ask questions here.
Feedback is welcome too.
Chris M
Chris M
13 years 10 months ago #27372
I have keyboard so it pop open and closed. I still need to change the layout and colors.
The DRO is for Fanuc style not sure if thats an improvement or not.
I'm thinking I could put the G and M code as a vertical list under the DRO - again more Fanuc style.
I see I could spend a lot of time making screens for people
Chris M
Chris M
13 years 10 months ago #27443
Time to create page: 0.303 seconds
