Gscreen - a GTK / Glade / Python based screen
13 years 5 months ago - 13 years 5 months ago #34110 by jlviloria
Chris
you can try something like mazaktrol used. that has a figure to recognize the tool is being done.
attached a picture.
thanks
Last edit: 13 years 5 months ago by jlviloria.
13 years 5 months ago - 13 years 5 months ago #34113 by cmorley
Jorge:
It was the way you added the time label to Glade - forced the screen too wide, wich doesn't allow full screen.
try this glade file:
Last edit: 13 years 5 months ago by cmorley.
13 years 5 months ago #34144 by LAIR82
Hello Chris,
I don't know if I stumbled on this on accident, or if its supposed to be, but does this screen look right?
After a little snooping around I realized that "Industrial" should look like this,
I'm thinking that it isn't right,
Although I do like it,
Also, in the actual "Industrial" skin, shouldn't the "Diameter Mode" button in the preferences change the relative readout to correspond with diameter or radius, I know that in the "hybrid" as I would call it, and have actually been using on my first Gscreen machine, it does change the relative readout for the X. In "Industrial" it stays as the radius value in the "setup" mode.
Thanks,
Rick
13 years 5 months ago #34165 by cmorley
The first screen is 'default skin' Gscreen set up for a lathe.
Second is 'Industrial skin' Gscreen looks like for a lathe too.
Yes the Diameter mode should change the relative readout - it's a bug you have found.
I'll look into it.
Chris M
13 years 5 months ago #34166 by LAIR82
Ok, for some reason I thought default gscreen was labeled a little differently.
Rick
13 years 5 months ago #34176 by cncboys
Hey everyone,
we are two students from germany and we've got a few problems with gscreen...
Firstly, I have to say that we are new in Linux and our Professor ordered us to install gscreen on a lathe within two weeks for a presentation....
Currently, the lathe works with EMC2 AXIS.
We downloaded the two gscreen files from the first site of this thread and found this link: wiki.linuxcnc.org/cgi-bin/wiki.pl?Gscreen#Installation
But to be honest, we don't really know what to do now. :blush: We changed the .ini file like it's said in this wiki tutorial, and we pasted the gscreen_preferences file into the home path.
But when we try to run the program, it says "Can't execute gscreen" in an error report.
Can anyone please help us, or give us a detailed tutorial?
Thank you!
Time to create page: 0.196 seconds
