New GUI for Emc available for testing...
16 years 7 months ago #2303 by ewlsey
This is fantastic!
I was really hoping something like this was coming.
I have one question. Will there be implementation for PyVCP widgets such as HAL indicators or spindle controls?
I will try to install and run the GUI, aber mein Deutsch ist nicht perfekt.
-Wes
16 years 7 months ago #2348 by penmaker1
Ok, I downloaded the file from the link in your first post. I have unzipped it and when I try to run the mocca file it tells me the parameters are incorrect. What parameters need to be either set as environment variables or added to the command line?
I am really looking forward to trying out your new GUI.
John Guenther
'Ye Olde Pen Maker'
Sterling, Virginia USA
16 years 7 months ago #2349 by gtom
Hi John, "mocca" is a gui like axis, tkemc etc... so you need to run it from the emc script.
Just put the binary inside the emc/bin path, make it executable.
Then you need to edit your config file and set the DISPLAY = mocca
When you start emc now with this configuration youll have mocca as the gui frontend...
The updated version will be released in about 2-3 weeks. it will be available in English also - in fact it is a binary with the design stored in xml- files so the user can modify the appearance of the gui like colors, fonts, position of controls, text etc...
regards, thomas
16 years 7 months ago #2350 by BigJohnT
Thomas,
That sounds pretty cool. Being able to modify the gui will be a cool feature.
Will it work on a lathe?
Would it be able to use a binary input for a feed override input? I know myself and Robh would like that feature.
16 years 7 months ago #2353 by eslavko
.... waiting English version. :woohoo:
16 years 7 months ago #2360 by penmaker1
Ok, I placed it in the appropriate place and added at DISPLAY = mocca line to the configuration file. Now when I run EMC i get the splash screen and then the error log pops up. Here is what I think is the relevant information from it:
Hal component "mocca" loaded.
could not open: /home/john/emc2/configs/Sherline4Axis/mocmdi.txt
Canon Offsets: 0.00 0.00
Shutting down and cleaning up EMC2...
I can send you the entire log file if you need it but I really did not want to clog up the forum with it.
Any help will be greatly appreciated.
I am running EMC 2.3.5 on a Ubuntu 8.04 Hardy Heron system loaded from the Live CD.
John Guenther
'Ye Olde Pen Maker'
Sterling, Virginia
