Touchy and Keyboard
16 May 2012 16:31 #20150 by VNR
Touchy and Keyboard was created by VNR
Hello,
I am working in a manual lathe conversion to CNC using LinuxCNC V2.5.0. Currently it is working with Axis, but i want to switch to Touchy. Before i make the CNC panel and buy a touch screen monitor i want to test it with the PC keyboard.
Do you have any example how to connect the Touchy button's (Abort/Start/Single block/Wheel counts) to the PC keyboard ?
Thanks you in advance,
Victor
16 May 2012 20:40 #20156 by BigJohnT
Replied by BigJohnT on topic Re:Touchy and Keyboard
IIRC touchy works with a mouse otherwise you can test with Axis until you get your touch screen.
17 May 2012 00:42 #20162 by cmorley
Replied by cmorley on topic Re:Touchy and Keyboard
you could use hal_input to connect a keyboard (like a second one) or any USB HID to connect to touchy.
I can't see any formal description in the manual on hal_input but there are man pages.
17 May 2012 12:52 - 17 May 2012 12:55 #20171 by VNR
Replied by VNR on topic Re:Touchy and Keyboard
It is working, the solution is:
INI File:
[DISPLAY]
EMBED_TAB_NAME=GladeVCP demo
EMBED_TAB_COMMAND=gladevcp -c gladevcp -x {XID} -u hitcounter.py -H gladevcp-touchy.hal manual-example.ui
gladevcp-touchy.hal file:
#Program Stop
net cb1 gladevcp.check => gladevcp.led1
#net cb1 => halui.program.stop
net cb1 => touchy.abort
#Program Run
net b1 gladevcp.button => gladevcp.led2
#net b1 => halui.mode.auto halui.program.run
net b1 => touchy.cycle-start
But now I HAVE A NEW PROBLEM:
In Touchy GUI the X and Z axis moves only at 100 mm/min regardless of G0 or G1 program code. That does not happen with Axis GUI.
Last edit: 17 May 2012 12:55 by VNR. Reason: Inserting JPG
17 May 2012 12:57 #20172 by VNR
100 mm/min is the only value, regardless of G0 or G1 program code.
17 May 2012 15:29 #20181 by andypugh
Replied by andypugh on topic Re:Touchy and Keyboard
Will it move slower than that? What happens if you increase feed-override?
Did you create a whole new config, or just change the GUI line in the INI file?
The first place I would look would be in the INI file in the [TRAJ] and {AXIS_N] sections.
18 May 2012 18:38 #20213 by VNR
I use the same ini file as in Axis GUI, wich is working OK. I only have changed in the ini file:
[DISPLAY]
#DISPLAY = axis
DISPLAY = touchy
and i have uncommented an EMBED_TAB_NAME and an EMBED_TAB_COMMAND in order to use Start and Stop buttons in a new GladeVcp tab panel.
Yes, if the G1 code is slower than 100 mm/min.
I don't know, but with halmeter i see:
motion.requested-vel 133.3333 (velocity mode, equals to 8000 mm/min)
motion.currente-vel 1.6666 (velocity mode, equals to 100 mm/min)
motion.requested-vel OUT FLOAT The requested velocity with no adjustments for feed override
motion.current-vel OUT FLOAT Current cartesian velocity
it doesn't make sense.
Victor
18 May 2012 18:53 #20215 by andypugh
You are right, it doesn't. What is feed override set to? (Should be visible somewhere in HAL)
18 May 2012 21:12 #20216 by VNR
halui.feed-override.value is set to 1
but thanks to your idea i have found halui.max-velocity.value set to 1.6666 (i don't know why) (x60 = 100 mm/min)
(halui.max-velocity.value float out Current value for maximum velocity)
so i set in hal:
setp halui.max-velocity.scale 50
and connect a "pulse" button to it:
net halui-pulses-maxvel touchy-buttons.hal_button_pulses_maxvel => halui.max-velocity.increase
the problem now is that the maximum value allowed for halui.max-velocity.value is 125 (7,5 mts/min) half the X and Z axis as is configured in the ini file (250 = 15 mts/min)
Any idea ? Is it a touchy bug ?
Victor
Time to create page: 0.101 seconds
