- Thank you received: 267
My custom designed GUI
8 years 6 months ago #109854
by KCJ
Replied by KCJ on topic My custom designed GUI
Grotius: Home all can trigger errors if a shared limit switch is closed when you initiate the homing sequence. I noticed that your python snippet uses an unusual homing sequence, XYZA. Typically you would home Z first to clear any work on the table, and then home X and Y simultaneously. Since neither X or Y will ever be homing at the same time as Z, a lot of configs will be set up to use the same input on the BOB for the X (or Y) and Z switches. So if the X switch is closed after homing (possibly due to poorly configured homing parameters in INI), and you try to re-home all it will fail as the the X and Z share the same input, and since X is already closed closing Z won't do anything.
tripwire: The above is probably the reason you could not get the X axis to home. You can configure multiple axis to home simultaneously in the INI. Just set both axes so they have the same homing sequence number.
The homing parameters in the INI allow for extremely flexible homing configuration, with out having to write any python code! I would strongly suggest you both look at homing documentation. It is one of the best documented parts of LCNC.
This has some very good explanations a diagrams:
linuxcnc.org/docs/devel/html/config/ini-...homing-configuration
Look at the Homing subsection in the INI docs (unfortunate it is not a link-able section):
linuxcnc.org/docs/devel/html/config/ini-config.html
Cheers,
Kurt
Cheers,
Kurt
8 years 6 months ago #109863
by tripwire
Thanks for the homing tip!
Replied by tripwire on topic My custom designed GUI
kcj wrote: tripwire: The above is probably the reason you could not get the X axis to home. You can configure multiple axis to home simultaneously in the INI. Just set both axes so they have the same homing sequence number.
7 years 9 months ago #124906
by alecuba16
Replied by alecuba16 on topic My custom designed GUI
Hello, someone has an updated version (for 2.
of this amazing gui?
- terminills
7 years 7 months ago #129897
by terminills
Replied by terminills on topic My custom designed GUI
I know this is an old thread but does anyone have this gui? I really like it.
7 years 7 months ago #129984
by persei8
Replied by persei8 on topic My custom designed GUI
It is cool but incompatible with the current Linuxcnc release. It would take a significant reprogramming effort. Considering the new GUIs currently in the pipeline, it's not worth the effort. However, you could probably make something that looks similar with the qtpyvcp environment.
The following user(s) said Thank You: KCJ
4 years 3 months ago #248316
by pietvr
Replied by pietvr on topic My custom designed GUI
I have made an update for LinuxCNC 2.8. The zipped file is unfortunately to big to upload here.
Here is a link to the zip on gdrive - craftsman2_8.zip
Cheers
Piet
Cheers
Piet
