Custom GUI and PyVCP
- Thank you received: 2162
13 Jun 2015 07:36 #59771
Replied by cmorley on topic Custom GUI and PyVCP
pyVCP can only display on the right or as stand alone panels.
tkinker doesn't support the XID protocol fully for embedding IFAIK.
Without some code changes in AXIS, you must use gladeVCP.
Chris M
Chris M
- vre
- Thank you received: 19
13 Jun 2015 20:11 - 13 Jun 2015 20:26 #59782
by vre
I have made a gladevcp panel for huanyang vfd hal component and works very nice.
Thanks John Thornton for his nice gladevcp tutorial.
Replied by vre on topic Custom GUI and PyVCP
Last edit: 13 Jun 2015 20:26 by vre.
The following user(s) said Thank You: alan_3301
- giggler999
20 Jun 2015 23:21 #60015
by giggler999
Replied by giggler999 on topic Custom GUI and PyVCP
This plugin appears broken in linuxcnc 2.6.8
Starting LinuxCNC...
**** GLADE VCP INFO: Not a builder project, trying to load as a lib glade project
(gladevcp:4834): libglade-WARNING **: Expected <glade-interface>. Got <interface>.
(gladevcp:4834): libglade-WARNING **: did not finish in PARSER_FINISH state
**** GLADE VCP ERROR: With xml file: huanyang.glade : could not create GladeXML object
<commandline>:0: gladevcp exited without becoming ready
Embeded tab command "halcmd loadusr -Wn gladevcp gladevcp -d -c gladevcp -x 71303832 -u handler.py huanyang.glade" exited with error: 1
TCL error in asynchronous code:
while executing
"163057292callit"
("after" script)
while executing
"163057292callit"
("after" script)
- giggler999
21 Jun 2015 00:13 #60016
by giggler999
linuxcnc 2.6.8
#sudo apt-get install glade
#glade
load "huanyang.glade" as LibGlade, then saveas LibGlade (not GDKBuilder), write over same file. Appears to work now.
#glade
21 Jun 2015 07:48 #60026
interesting what linux distribution are you using?
- vre
26 Jun 2015 05:39 #60136
by vre
I have tested gladevcp panel to linuxcnc 2.7 not 2.6
06 Jul 2015 12:12 #60461
No I meant what distribution of linux?
Wheezy or Ubuntu?
either way you should be using glade-gtk2 version of the GLADE editor.
Chris M
Wheezy or Ubuntu?
Chris M
Time to create page: 0.323 seconds
