Semi Manual Tool Changes in Gmoccapy
- thewho
08 Jul 2015 18:34 #60512
by thewho
Semi Manual Tool Changes in Gmoccapy was created by thewho
Hello
I have a vmc with an automatic tool changer that I haven't got working yet. So now I change toolholders manually.
This is the first machine I use Linuxcnc and with the capability to change tools with offsets.
The problem is that I cant get the offsets to work!
This is how I'm trying to do it:
1. Put manual probe "tool 0" in spindle
2. Find corner of workpice
3. Zero Z height
4. Open the "tooleditor" screen
5. Select the first tool required for selected job
6. Press the "M61 Q?" button
Is this the correct way to do it?`
Because when I do that no Z offset is loaded. The "tool information" box shows everything correct except "offset Z" that is always 0.
Do I need to edit any hal files for this to work?
3. Zero Z height
- Thank you received: 4966
08 Jul 2015 19:23 #60519
It is part of the correct way but you also need to issue a G43 command to load the tool offsets.
M61 Q99 G43 will probably work, but if not then M61 Q99 G43 H99.
Replied by andypugh on topic Semi Manual Tool Changes in Gmoccapy
The following user(s) said Thank You: DoWerna
- thewho
08 Jul 2015 19:33 #60521
by thewho
Replied by thewho on topic Semi Manual Tool Changes in Gmoccapy
I don't think that is the problem though.
wiki.linuxcnc.org/cgi-bin/wiki.pl?GmoccapyPlease note, that gmoccapy takes care of its own to update the offsets,
sending an G43 after any tool change, but not in auto mode!
- newbynobi
- Thank you received: 414
09 Jul 2015 01:55 #60529
by newbynobi
Replied by newbynobi on topic Semi Manual Tool Changes in Gmoccapy
Hallo,
that is correct, but...
gmoccapy will only apply an offset for the new tool, if an G43 is active!
So after the touch off, you will have to give once the G43 command, than gmoccapy will take care after every following change.
I did program this behavior on purpose, because there are also users not using offsets at all.
Norbert
Norbert
- thewho
10 Jul 2015 01:20 #60542
by thewho
Ah ok
So what is the correct way to do all this?
1. Start machine
2. Start Linuxcnc
3. Home all axis
4. Put probe (tool 0) in spindle
5. Zero XYZ on part
6. Write "G43 H0" in MDI??
7. Put first tool in spindle
8. Select that tool in the tool table
9. Press "M61 Q?"
Because I can't get that to work
1. Start machine
2. Start Linuxcnc
3. Home all axis
5. Zero XYZ on part
9. Press "M61 Q?"
- thewho
11 Jul 2015 00:16 #60545
by thewho
Something I found out today:
If I use Axis and follow this tutorial: gnipsel.com/linuxcnc/g-code/gen05.html
And when I do an "T1 M6 G43" in MDI Linuxcnc becomes terribly slow and unresponsive. If I press the "manual control" tab it takes like 10seconds before it changes to that tab.
Same result after I deleted the tool.tbl.
I ask again, is there something that has to be done in some HAL-file for this to work? I used pncconf to get the machine running and have not added anything regarding tool changes myself.
- newbynobi
11 Jul 2015 21:50 #60565
by newbynobi
gmoccapy related
Please do the following:
axis related:
I am pretty sure, that you have not included manual_tool_change.hal in your INI.
Norbert
- get out of e-stop
- turn on the machine
- home all axis
- go to tool page and selegt your reference tool, your edge finder
- change tool to the selected one
- go to mdi page and give "G43" (even if your tool has only zero offsets!)
- touch off your workpiece
axis related:
Norbert
- thewho
12 Jul 2015 04:57 #60574
by thewho
Got it working with Axis at least now (haven't tried gmoccapy)
Added this to my hal file:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Tool_Changes
Thanks for your answers anyway
Time to create page: 0.301 seconds
