Glade exits without warning
11 years 2 months ago - 11 years 2 months ago #61918 by racedirector
I think I have cured mine, I trashed the Debian install and installed Xubuntu 12.04, manually installed the kernel and LCNC 2.6.9 along with Glade, still version 3.8.0 and so far no crashes at all. I even had 3 copies of Glade open at the same time and none of them died without warning. No idea why the difference but I am happier right now.
Last edit: 11 years 2 months ago by racedirector.
8 years 11 months ago #102063 by Gene1934
I have this problem also and it seems to be related to how close to the camera'd native format in terms of its native 640x480 size is expand the axis gui to. If the tab window remain 40 os so pixels smaller that the camera, it sees to work, but get any closer that 550x390 pixels and it will exit and cannot be started without restarting LCNC. When t exits, it logs this line to the terminal LCNC was launched from.
/usr/bin/gladevcp:295: Warning: g_object_ref: assertion `object->ref_count > 0' failed
gtk.main()
I would like very much to be able to expand LCNC's gui to full screen without gladevcp's untimely death.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
8 years 11 months ago - 8 years 11 months ago #102211 by newbynobi
I use glade 3.8.6 and do not suffer that problems. The mentioned problems are bugs in releases prior to 3.8.5 I recommend to update from sources.
See this thread:
How To Glade 3.8.6
Norbert
Last edit: 8 years 11 months ago by newbynobi.
Time to create page: 0.116 seconds
