hazzy - Another touchscreen GUI
9 years 2 months ago - 9 years 2 months ago #97076 by KCJ
Replied by KCJ on topic hazzy - Another touchscreen GUI
I designed Hazzy to fill an entire 1024x768 screen, so if you have launcher panels or anything else that takes up screen real estate it will not fit. I am currently working on making the UI salable to fit different screens sizes and resolutions, so I should have the resolved eventually.
The 'tools' symbol in the gremlin controls is suposed to bring up the same menu as when you right click gremlin, but I had some trouble making that work so it does nothing at the moment. Hopefully those controls (and others) will be in a popover menu some time soon.
I have physical potentiomenter based Feed, Speed and Rapid ORs on my machine, but I am planning to add on screen overrides to Hazzy as soon as I figure out were to put them!
I am currently trying to migrate the from GTK2 to GTK3 for the UI, which will give me a lot more flexibility in how the on screen controls can be done. I am also thinking about maybe completely changing the UI design to make it more touch friendly and easier to customize. I hope to post some mock ups in the near future for you all the criticize. Thinking maybe more like a CELOS control, but without all that flashy appy junk...
Last edit: 9 years 2 months ago by KCJ.
9 years 2 months ago #97077 by massimodamassa
Welcome back, I remember the lathe
It would be for this
The following user(s) said Thank You: KCJ
9 years 2 months ago #97078 by KCJ
I have not forgotten about your lathe! I can't wait for Hazzy to be able to run such a nice machine, I am very jealous :)
9 years 2 months ago #97102 by massimodamassa
It all depends on you:) :silly: ;)
9 years 2 months ago #97152 by sqmathlete
Hi Massimodamassa,
Totaly inspiring to see your machine work. I have a Mazak Slanturn that I am working on with Delta ASDA-Servo amps as well. Would you be willing to share you configuration? I am currently still trying to get .xml file sorted... Any help would greatly be appreciated.
By the way, Kcj Fantastic Gui!
Mazak watch out!
Dan
9 years 2 months ago #97159 by massimodamassa
Here is the .xml file for alerts alongside.
I claim that I used a mesa 5i22-1 and command the stepper / dir engines, the closed loop make the delta.
Time to create page: 0.453 seconds
