Plot widget for QtPyVCP
- scotta
 - Thank you received: 486
						20 Jun 2019 20:44		 -  20 Jun 2019 20:46		#137416
		by scotta
				Plot widget for QtPyVCP was created by scotta
				I've developed a HalPlot widget for QtPyVCP. Currently it only can plot two Hal pin inputs as a scrolling time plot. Sample frequency, displayed time window and plot series pen settings are available as parameters in Designer. My intention is to use this in a 3D printer UI but it would be useful in other situations as well.
Scott
					Scott
		Last edit: 20 Jun 2019 20:46  by scotta.
		The following user(s) said Thank You: BigJohnT, TurBoss, tommylight, Lcvette, KCJ
- BigJohnT
 - Thank you received: 994
						20 Jun 2019 23:58				#137435
		by BigJohnT
				Replied by BigJohnT on topic Plot widget for QtPyVCP
				Are you going to do a PR to add this to QtPyVCP?
JT
					JT
		The following user(s) said Thank You: KCJ
- KCJ
 - Thank you received: 267
						21 Jun 2019 00:33				#137436
		by KCJ
				Replied by KCJ on topic Plot widget for QtPyVCP
				Scott, you did it, fantastic work!
This would be a great addition the the QtPyVCP HAL widgets if your willing to share.
What plot toolkit did you end up using?
Cheers,
Kurt
Cheers,
Kurt
- scotta
						21 Jun 2019 06:39				#137457
		by scotta
				Replied by scotta on topic Plot widget for QtPyVCP
				Definitely! I'm a great believer in open source and sharing. I ended up using pyqtgraph. I will add some additional Hal pin inputs so that a total of 4 series can be plotted. This is what I need for my application. It would be great to add these dynamically but I have no idea how to do this at the moment.
I have also never used GitHub so cannot submit a pull request. A quick lesson would be appreciated
Scott
Scott
- BigJohnT
						21 Jun 2019 10:32		 -  21 Jun 2019 10:40		#137481
		by BigJohnT
				In the development guide:
qtpyvcp.kcjengr.com/development/dev_environment.html
This might also be a good tutorial on doing a pull request.
yangsu.github.io/pull-request-tutorial/
JT
JT
		Last edit: 21 Jun 2019 10:40  by BigJohnT.
- Lcvette
 - Thank you received: 712
						21 Jun 2019 13:56				#137487
		by Lcvette
				Replied by Lcvette on topic Plot widget for QtPyVCP
				Scotta,
Great work!! you should join us in the QtPyVCP Chat on the IRC! its a great place to share ideas and work product for QtPyVCP!
Chris
Chris
- scotta
						22 Jun 2019 00:32				#137529
		by scotta
				QtPyVCP is developing quickly! I thought that I had read most of the documentation but totally missed the Contribution Guide. I really need to get up to speed with GitHub and stop working just locally on my machine.
I'm off to Asia again for a week for work, but when I get back I'll setup a branch and try to get the pull request sorted.
How do access the IRC? This will help speed up my work maybe. I spend a lot of time looking at other peoples work to get ideas and code snippets.
Scott
Scott
- BigJohnT
						22 Jun 2019 19:31				#137613
		by BigJohnT
- scotta
						06 Jul 2019 22:09		 -  07 Jul 2019 07:22		#138760
		by scotta
				So I think I'm happy to do a pull request on HalPlot. It has all of the functionality that I need now but others may find some more enhancement opportunities.
Up to four HAL pins can be plotted, enabled via Qt parameters, and the exposed qtpyvcp pin is now using the plot series name. Each series has pen settings in Designer and the legend can also be enabled or disabled as required.
Just need to put it into action now
		Last edit: 07 Jul 2019 07:22  by scotta.
- TurBoss
 - Thank you received: 81
						08 Jul 2019 20:18		 -  08 Jul 2019 20:22		#138888
		by TurBoss
				Replied by TurBoss on topic Plot widget for QtPyVCP
		Last edit: 08 Jul 2019 20:22  by TurBoss.
		Moderators: KCJ, Lcvette
		Time to create page: 0.127 seconds
