Couple of qtpyvcp questions
  • persei8
  • persei8's Avatar Topic Author
  • Platinum Member
  • Platinum Member
22 Aug 2019 17:57 #142865 by persei8
Couple of qtpyvcp questions was created by persei8
First, should there be a whole new main category under "User Interfaces" called QTPYVCP instead of it being covered in "Other User Interfaces"?
Second, if I want to do some periodic stuff in a qtpyvcp based gui, do I use the gobject.timeout_add(time, handler) template or is there a new/preferred way to do it? This is the last thing holding me up in my silverdragon conversion to qt. Thank you.
22 Aug 2019 23:04 #142886 by cmorley
Replied by cmorley on topic Couple of qtpyvcp questions
Are you talking qtpyvcp or qtvcp?
Chris
22 Aug 2019 23:28 #142895 by BigJohnT
Replied by BigJohnT on topic Couple of qtpyvcp questions
Chris is qtvcp in master only or is it in 2.8? I don't see it in the documents for 2.8.
JT
22 Aug 2019 23:33 #142896 by cmorley
it's in 2.8. Are there online docs for 2.8?
Chris
22 Aug 2019 23:44 - 22 Aug 2019 23:45 #142902 by BigJohnT
Yes linuxcnc.org/docs/2.8/html/
Oh I see it now, I was looking in user interfaces for it not virtual control panels. It is a user interface right?
JT
Last edit: 22 Aug 2019 23:45 by BigJohnT.
  • persei8
  • Platinum Member
  • Platinum Member
22 Aug 2019 23:47 #142904 by persei8
Replied by persei8 on topic Couple of qtpyvcp questions
Qtpyvcp (I think) The one for full custom GUIs. In order to implement a program progress bar, I need to periodically get the currently executing line number of the gcode file. If it's in the documentation, I will check again.
22 Aug 2019 23:50 #142905 by cmorley
is it included with linuxcnc or a separate program?
Chris M
  • persei8
  • Platinum Member
  • Platinum Member
23 Aug 2019 00:42 #142909 by persei8
I don't know. It is now obvious I don't understand as much as I thought so it's back to the drawing board. Am I at least correct in thinking that qtvcp is analagous to gscreen?
23 Aug 2019 04:21 #142917 by cmorley
Yes it's unfortunate there is a qtvcp include with linuxcnc's source and there is a qtpyvcp that is a separate project ( to be used with linuxcnc)
Qtvcp is analogous to gscreen - it uses similar ideas (on purpose).
To answer your question in Qtvcp:
STATUS.connect('periodic',self.periodic_update)
Will call a function named:
def periodic_update(self,w):
every 100ms.
But for a progress bar of % completed lines there is another way:
There is a signal send from the gcode editor called percentDone that can be connected to a progrssBars setValue slot using the Designer signal/slot editor.
The blender example uses this technique.
Chris M
The following user(s) said Thank You: persei8
23 Aug 2019 17:28 #142983 by cmorley
JT
Hey John when I visit this page:
linuxcnc.org/docs/
One can not select 2.8 docs.
Chris
Moderators: KCJ, Lcvette
Time to create page: 0.190 seconds
