Couple of qtpyvcp questions
- persei8
- Thank you received: 133
23 Aug 2019 17:29 #142984
by persei8
Replied by persei8 on topic Couple of qtpyvcp questions
Unfortunately, I don't think qtvcp and qtpyvcp can coexist. I cannot get designer -qt=5 to work but editvcp works just fine. What I did is create a GUI within an environment as defined at qtpyvcp.kcjengr.com/index.html. I do not see any signals called percentDone for the gcode editor widget. However, your reply has given me the means to make some progress. To make a periodic timer, I use :
from PyQt5.QtCore import QTimer
class (blah blah)
self.timer = QTimer()
self.timer.timeout.connect(self.handleTimer)
self.timer.start(1000)
def handleTimer(self):
etc.
On to the next problem.
class (blah blah)
etc.
- Thank you received: 2181
23 Aug 2019 17:34 #142985
Replied by cmorley on topic Couple of qtpyvcp questions
Ahh yes you are using qtpyvcp.
Qtpyvcp doesn't use gobject.
Glad I could off handily help
Chris
Chris
- BigJohnT
- Thank you received: 994
23 Aug 2019 20:38 #143008
by BigJohnT
That's the 2.7 documents, To select a different version you have to go to the main LinuxCNC page and select Documents to view the selections for current documents or Archives for past versions.
JT
Replied by BigJohnT on topic Couple of qtpyvcp questions
Hey John when I visit this page:
linuxcnc.org/docs/
One can not select 2.8 docs.
Chris
JT
- persei8
23 Aug 2019 20:49 #143009
by persei8
While the timer works, it's not the way to go. Your other suggestion is the one I am trying to implement. Is there a way to read the total number of lines contained in the gcode editor? I cannot find any documentation regarding gcode editor signals.
24 Aug 2019 01:36 #143024
It is the page to select which version of docs you wish to see.
Chris
Did you actual check the link I posted?
linuxcnc.org/docs/
Chris
JT
Chris
24 Aug 2019 01:38 #143025
So you are using qtpyvcp - this is a completely different project base then qtvcp.
They are very similar but not compatible.
So my suggestion to you is useless.
I don't know much about qtpyvcp - it's developed outside of linuxcnc.
Chris
Chris
- persei8
24 Aug 2019 02:07 #143029
by persei8
Yeah I figured out they were incompatible. However, I am so far into it now that I do not want to switch over. Anyway, it turns out I do need the timer because if you update the progress bar too quickly, it causes a segmentation fault. I now have the progress bar working so you will not hear any more about it.
And your suggestions are far from useless. Even the smallest hint can be used to start down the right path to a solution. Thank you.
- Thank you received: 4654
28 Aug 2019 20:33 #143473
How dod you get there?
linuxcnc.org/documents/
Seems to work.
linuxcnc.org/docs/
Doesn't work. Did you use an old bookmark?
Replied by andypugh on topic Couple of qtpyvcp questions
Seems to work.
linuxcnc.org/docs/
28 Aug 2019 20:39 #143475
yes - and it gives more options - all docs are available
linuxcnc.org/docs works for me other then 2.8 is missing.
Thanks for looking into it.
Chris
Chris
- BigJohnT
29 Aug 2019 23:16 #143616
by BigJohnT
The linuxcnc.org/docs is the current stable release with no options to view any other versions. To view all the documents you have to go to linuxcnc.org and start from there.
JT
Chris
JT
Moderators: KCJ, Lcvette
Time to create page: 0.195 seconds
