Probe Basic
- OldSQL
30 Mar 2024 11:00 - 30 Mar 2024 11:02 #297204
by OldSQL
Probe Basic was created by OldSQL
Hello,I'm converting my machine from using Axis config to Probe Basic Config. I encountered this error.
Debug file information:
iopl() failed: Operation not permitted
cannot gain I/0 privileges - forgot "sudo make setuid' or using secure boot? -par
allel port access is not allowed
Note: Using POSIX realtime
/home/cnc/linuxcnc/configs/OMNI/OMNI.ini:65: executing '"import sys
sys.path.append("/home/cnc/linuxcnc/configs/OMNI/python/")
PythonPlugin: Python '3.11.2 (main, Mar 13 2023, 12:18:29) [GCC 12.2.0]
/home/cnc/linuxcnc/configs/OMNI/OMNI.ini:65: executing "import sys
is_callable(__init__) = FALSE
9682
9732
is_callable(_delete) = FALSE
Stopping realtime threads
Unloading hal components
cannot gain I/0 privileges - forgot 'sudo make setuid' or using secure boot? -par
I've already upgraded the software, but it persists. I can open the configuration with the terminal.Can anyone help?
9682
9732
Last edit: 30 Mar 2024 11:02 by OldSQL. Reason: Miss info
- Thank you received: 7481
30 Mar 2024 14:34 #297211
Replied by tommylight on topic Probe Basic
Is this a "run in place" or normal install?
Operation not permitted is usually when using run in place and not setting permissions, or on normal install if you run LinuxCNC as root user or with sudo.
- OldSQL
30 Mar 2024 19:44 #297228
by OldSQL
Replied by OldSQL on topic Probe Basic
It's a normal configuration, I did a new one.
Maybe I did something wrong, I can reset.
If it persists could be something wrong about pb installation?
- OldSQL
31 Mar 2024 17:32 #297297
by OldSQL
It persists, how can I set the permissions u talked about?
01 Apr 2024 03:07 #297324
Try disabling "secure boot" in BIOS.
- OldSQL
01 Apr 2024 15:28 #297376
by OldSQL
I disable secure boot and it continues to show the same error.
Could be something wrong in Probe Basic installation?
01 Apr 2024 15:58 #297380
Yes it could be, so try installing it again, but be very careful to use "sudo" only when it says so.
And never use "sudo -i" or "su".
- OldSQL
02 Apr 2024 13:19 #297432
by OldSQL
Yes, SIM works well, but when I migrate a functional config it won't launch. Can even load the hal components.
Install PB again.
Install PB again.
02 Apr 2024 14:41 #297436
If sim works, there is probably something amiss with the editing/adding your config, but very hard to pin point without more info.
- OldSQL
02 Apr 2024 15:22 #297439
by OldSQL
2557
2605
Always this problem...
2557
2605
Time to create page: 0.101 seconds
