Proposed removal of 'gscreen/silverdragon' simulation config in master
  • Aciera
  • Aciera's Avatar Topic Author
  • Administrator
  • Administrator
01 Sep 2024 07:53 #309145 by Aciera
There is discussion about removing the 'sim.gscreen.silverdragon' simulation config in master as it fails on load with Gtk related errors on current debian bookworm installations as well as RIP installation of both 2.9.x and master.
So, if anybody has actually managed to run the 'sim.gscreen.silverdragon' simulation config in 2.9.x please drop a note. github.com/LinuxCNC/linuxcnc/issues/3094
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
07 Sep 2024 12:14 #309591 by andypugh
I have managed to run it. But it took some work.
I plan to update the others in the same way tomorrow.
It's mainly a case of loading the ui into a newer version of glade and then re-saving.
The following user(s) said Thank You: tommylight, Aciera
Time to create page: 0.536 seconds
