Flex GUI Hole Ops
- JT
 - Thank you received: 536
						23 Nov 2024 14:34		 -  24 Nov 2024 14:30		#315107
		by JT
				Flex GUI Hole Ops was created by JT
				Hole operations using parameters set from the GUI in subroutines.
JT
					JT
		Last edit: 24 Nov 2024 14:30  by JT.		Reason: Update the url
 - Thank you received: 7113
						24 Nov 2024 22:44				#315194
				Replied by tommylight on topic Flex GUI Hole Ops
				Nicely done, maestro.
Thank you.
					Thank you.
- JT
						25 Nov 2024 00:53				#315206
		by JT
				Replied by JT on topic Flex GUI Hole Ops
				Actually Tom from the IRC programmed the subroutines and made that GUI I just gave him the tools to do the job. Flex GUI is getting to be quite flexible and powerful. I like to think of Flex GUI is like LinuxCNC you can do anything you can think of and you're not forced to use what some programmer thinks you need.
JT
					JT
		Time to create page: 0.111 seconds
