Touchy error
1 year 11 months ago #315702 by cmorley
Replied by cmorley on topic Touchy error
There is QtTouchy available in linuxcnc as well.
1 year 11 months ago #315731 by JT
Replied by JT on topic Touchy error
When I tried the Qt Touchy it would not start and gave this error as well as some strange noise out the speakers.
Running Debian 12
JT
1 year 11 months ago #315732 by tommylight
1 year 11 months ago #315758 by cmorley
Hey John, can you run it in a terminal so I can see what line the error came from?
Newer versions of Qt are picker about ints and floats.
1 year 10 months ago - 1 year 10 months ago #315781 by JT
Hope this helps.
Full error from the popup error
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/widgets/tab_widget.py", line 43, in tabSizeHintreturn QSize(size.width(), w)^^^^^^^^^^^^^^^^^^^^^^TypeError: arguments did not match any overloaded call:QSize(): too many argumentsQSize(w: int, h: int): argument 2 has unexpected type 'float'QSize(a0: QSize): argument 1 has unexpected type 'int'
JT
Last edit: 1 year 10 months ago by JT. Reason: add popup error
1 year 10 months ago #315782 by tommylight
Replied by tommylight on topic Touchy error
It can not find axis number 3, but it does continue loading...
Time to create page: 0.057 seconds
