FlexGui touch - FSC-like myOwn tab from ext UI file
- ts
						10 Sep 2025 07:20		 -  10 Sep 2025 12:45		#334752
		by ts
				FlexGui touch - FSC-like myOwn tab from ext UI file was created by ts
				Hello
Im trying to include my own tab to flex gui touch (great wotks! Thanks to author!). I see that already there fsc_container which corresponds to /usr/lib/libflexgui/fsc.ui and now i wanna to add my own tab - for example i have some rs232 device to read some parameters (thc, edm for example, device already connected to hal via user space component linuxcnc). And i dont understand how to include thc.ui to the tab like dsf / fsc ?
		Last edit: 10 Sep 2025 12:45  by ts.
- JT
- Thank you received: 536
						12 Sep 2025 11:59				#334878
		by JT
				Replied by JT on topic FlexGui touch - FSC-like myOwn tab from ext UI file
				The simple way is to just create your tab in the ui and add your widgets then using the Python module connect all of your widgets to your Python code.
gnipsel.com/linuxcnc/flexgui/python.html
github.com/jethornton/flexgui/blob/maste...gui/startup.py#L2381
github.com/jethornton/flexgui/blob/maste...rc/libflexgui/tpc.py
JT
JT
		The following user(s) said Thank You: ts
- ts
						23 Sep 2025 14:55				#335327
		by ts
				Replied by ts on topic FlexGui touch - FSC-like myOwn tab from ext UI file
JT thanks for your reply.
additional for this situation question. I have two sliders. Usong Slider1 user may choose value 10..20. slider2 could be 0..100 . But if slider1 is more than 15, Slider2 could be only 80..100.
How i may realise this?
Thanks in advance.
Thanks in advance.
- JT
						23 Sep 2025 15:38				#335328
		by JT
				That would have to be done in your custom Python code using the sliders valueChanged() signal to trigger a call to your function and use the setMinimum() function of the slider to change the minimum set point.
JT
					JT
- JT
						23 Sep 2025 16:13				#335330
		by JT
				I just tried this and it works fine
					from functools import partial
def startup(parent):
	parent.slider_1.valueChanged.connect(partial(slider_1, parent))
	parent.slider_2.valueChanged.connect(partial(slider_2, parent))
def slider_1(parent):
	parent.label_1.setText(f'{parent.slider_1.value()}')
	if parent.slider_1.value() >= 15:
		parent.slider_2.setMinimum(80)
	else:
		parent.slider_2.setMinimum(0)
def slider_2(parent):
	parent.label_2.setText(f'{parent.slider_2.value()}')
- JT
						23 Sep 2025 16:18				#335331
		by JT
- ts
						27 Sep 2025 06:29				#335477
		by ts
				Hi, JT!
thanks a lot.
Its works fine.
Also im used parent.slider1.setSliderPosition(int) for setting needed value with 'if' to controlling the range without changing min/max.
Best regards
					thanks a lot.
Its works fine.
Best regards
		Time to create page: 0.087 seconds
