Flex Gui Jog after toolchange
25 Sep 2025 21:37 - 26 Sep 2025 21:42 #335438 by MaHa
Flex Gui Jog after toolchange was created by MaHa
Coming up with another problem:
When using toolchange with combobox toolselection and pushbutton, Toolchange gets completed.
Trying to jog with jog pushbutton afterwards, this error appears for any axis
Joint jog requested for undefined joint number=-1 (min=0,max=3)
Doing toolchchange Tn M6, jog works without problem
When a MDI command movement of any axis is done, afterwards jog is possible without error
Last edit: 26 Sep 2025 21:42 by MaHa.
29 Sep 2025 09:41 #335536 by JT
Replied by JT on topic Flex Gui Jog after toolchange
I can duplicate that error so should be fixed shortly.
JT
The following user(s) said Thank You: MaHa
29 Sep 2025 11:27 #335539 by JT
This has been fixed, thanks for the report.
JT
Time to create page: 0.082 seconds
