FlexGui QDoubleSpinBox HAL_IO
10 Oct 2025 22:24 #336243 by MaHa
FlexGui QDoubleSpinBox HAL_IO was created by MaHa
It is very difficult or impossible to enter a floatingpoint value at once. I can enter only 1 digit, then the rest of the box is filled with zeros. So i have to select each digit and replace, minus can only be entered separately also. The input for variable works much better.
13 Oct 2025 12:22 #336378 by JT
Replied by JT on topic FlexGui QDoubleSpinBox HAL_IO
Found the bug and fixed it, thanks for the report.
JT
The following user(s) said Thank You: tommylight, MaHa
Time to create page: 1.315 seconds
