Usable Interface for CNC Turntable on Manual Mill
11 months 4 weeks ago #337731
by Pinaz993
Usable Interface for CNC Turntable on Manual Mill was created by Pinaz993
Greetings, all. I am currently helping a relative with a small project. He is a machinist, and has a manual horizontal mill. For this mill, he has a small manual turntable, which he is hoping to be able to automate to some degree.
The stepper motor that has been purchased to drive the turntable does not have enough torque to machine with, even at a 40:1 reduction. However, it should be able to turn the turntable a given number of degrees in a given direction, and then the turntable can be locked down before proceeding with the machining process.
I have the official LinuxCNC Debian image installed on a Pi4 (and have fixed the GPIO permissions issue), and have configured the X axis as angular, with no other axis in the configuration. I can put in the 40:1 gearing.
My problem is that I haven't the foggiest idea what interface to use. I need something that can order a rotation of a certain amount of degrees and then a stop, as well as switching between clockwise and counterclockwise. However, all the interfaces I've seen are specifically designed to run Gcode from CAM software. Is there an interface that supports these needs, or do I need to code something myself?
11 months 4 weeks ago #337734
by unknown
Replied by unknown on topic Usable Interface for CNC Turntable on Manual Mill
Linuxcnc is probably overkill for this situation.
If you look around YouTube you'll find plenty of projects addressing this idea.
Myfordboy has done such a project but using a spin indexer.
The following user(s) said Thank You: timo
11 months 4 weeks ago #337746
Replied by rodw on topic Usable Interface for CNC Turntable on Manual Mill
Its not very hard to do this with an Arduino (even for me) and there are several such indexers available. Sorry but I don't think I have the code anymore.
11 months 4 weeks ago #337747
by Hakan
Replied by Hakan on topic Usable Interface for CNC Turntable on Manual Mill
The interface has a manual mode where you can jog to an angle.
Or enter G0 X-40 in the MDI for it to go to -40 degrees.
11 months 4 weeks ago - 11 months 4 weeks ago #337753
by JT
Replied by JT on topic Usable Interface for CNC Turntable on Manual Mill
The Flex GUI is the best interface for this because you can have as little or as much as you want. Also it's based on PyQt6 which is the latest so it will be supported for a long time. All the rest of the GUI's assume you have a standard mill or lathe and are based on the now retired PyQt5. Flex GUI assumes nothing. If you want a GUI with two jog buttons it's rather simple.
gnipsel.com/linuxcnc/flexgui/index.html
On Libera.Chat #flex-dev or #linuxcnc you can get rapid help for Flex GUI usually.
FYI
Standard support for Qt 5.15 LTS (the last release of the Qt 5 series) ended on May 26, 2023. This means that open-source users no longer receive community updates or security patches for Qt 5.
JT
FYI
JT
Last edit: 11 months 4 weeks ago by JT.
11 months 4 weeks ago - 11 months 4 weeks ago #337881
by timo
Replied by timo on topic Usable Interface for CNC Turntable on Manual Mill
Hello,
we had a longish discussion about using an arduino for this task; here:
www.homemodelenginemachinist.com/threads...rduino-idexer.35108/
and here:
www.homemodelenginemachinist.com/threads...e-for-dummies.26744/
Be careful with rounding errors and backlash, but for simple indexing this does work fine.
With an Arduino and stepper that is rel. slow, but I would prefer it over a linux CNC system, because it "stand alone" and cheap and easy to build.
The second link is good for the basic setup and wiring description.
The first link dives into the rounding error explanation.
Good luck.
and here:
Good luck.
Last edit: 11 months 4 weeks ago by timo.
Time to create page: 0.092 seconds
