Hello Sandro,
Thank you for sharing lcnc-suite — it's a genuinely impressive piece of work, and the 3D toolpath preview alone saved me weeks of development time.
I'd like to report that I've successfully used lcnc-suite as the frontend for a **non-LinuxCNC** CNC system, in case it's useful to you or others here.
**My Setup**
- SBC: Arduino UNO Q (Qualcomm QRB2210, Debian 13, Python 3.13)
- Motion controller: STM32U585 running grblHAL, connected via internal UART (ttyHS1)
- G-code interpreter: rs274ngc (from the linuxcnc-uspace package — the C extension only, no linuxcnc task/HAL)
- Machine: CoreXY pen plotter with CNC Shield V3
The key idea: instead of `import linuxcnc`, I wrote a custom FastAPI/asyncio gateway in Python that speaks the lcnc-suite WebSocket protocol on one side and rs274ngc + grblHAL on the other. This means lcnc-suite can work with backends other than LinuxCNC.
**What works**
File upload, 3D toolpath preview, program execution (rs274ngc → grblHAL streaming), step execution, jog (continuous + incremental + diagonal), E-STOP/pause/resume/abort, WCS switching (G54–G59), spindle and coolant control, file browser — everything I've tried works well.
**Undocumented requirements I found**
While building the gateway I hit a few things not covered in the README. Posting them here in case they help someone else attempting the same:
1. **`heartbeat` must return `{"type": "pong"}`** — any other response causes the WebSocket to disconnect after ~20 seconds.
2. **`GET /settings` is required on startup** — without it the UI enters a reload loop.
3. **`save_settings` WebSocket command must be handled** — sent frequently for jog speed etc., causes visible errors otherwise.
4. **`GET /gcode?path=...` is needed after upload** — the UI fetches file content via this endpoint to display in the editor.
5. **`GET /files` must return `FilesResponse` format** (`{ok, nc_dir, subdir, entries[]}`) — a plain array causes "No program files found".
6. **`status` broadcast must include `armed` field** — needed for the ON button to activate after ARM.
I've opened a GitHub issue with full details:
github.com/bildobodo/lcnc-suite/issues
The gateway source is here if anyone wants to look:
github.com/hoshigarasu/canon-grbl-bridge
Thanks again for building and sharing lcnc-suite.
