- User Interfaces
- Other User Interfaces
- linuxcncrsh crashes when get_spindle or get_spindle_overide commands executed
- galmiklos
23 Aug 2026 21:43 - 23 Aug 2026 21:58 #348949
by galmiklos
linuxcncrsh crashes when get_spindle or get_spindle_overide commands executed was created by galmiklos
Running linuxcnc 2.9.10 with linuxcncrsh loaded. When a client connects and executes a get spindle or get spindle_override command, linuxcncrsh crashes with segmentation fault.
This is the line in custom.hal.
linuxcncrsh started like this
These are the commands on the client side.
[/code][/code][/code]
[code]loadusr linuxcncrsh --port 5007 --connectpw EMC --enablepw EMCT00linuxcncrsh started like this
[code]gal@linuxcnc-vm:~/linuxcnc/configs/sim.qtdragon_hd.qtdragon_hd_xyz$ linuxcncrsh -p 5007 -w EMC -e EMCT00 -- -ini /home/gal/linuxcnc/configs/sim.qtdragon_hd.qtdragon_hd_xyz/qtdragon_hd_xyz.ini
Connected to telnet
Segmentation faultThese are the commands on the client side.
[code]gal@roki:~$ telnet 192.168.3.125 5007
Trying 192.168.3.125...
Connected to 192.168.3.125.
Escape character is '^]'.
hello EMC telnet 1.0
HELLO ACK EMCNETSVR 1.1
get spindle
get spindle
Connection closed by foreign host.[/code][/code][/code]
Last edit: 23 Aug 2026 21:58 by galmiklos.
- Thank you received: 2177
24 Aug 2026 10:43 #348958
Replied by Aciera on topic linuxcncrsh crashes when get_spindle or get_spindle_overide commands executed
There has been a fair bit of work going on there.
Could you raise an issue on GitHub?
github.com/LinuxCNC/linuxcnc/issues
If not then I can open one and link here but it would be better to have you in the loop.
- Thank you received: 7506
24 Aug 2026 11:00 #348960
Replied by tommylight on topic linuxcncrsh crashes when get_spindle or get_spindle_overide commands executed
Is LinuxCNC running inside a VM or bare metal?
- galmiklos
24 Aug 2026 11:22 #348962
by galmiklos
Replied by galmiklos on topic linuxcncrsh crashes when get_spindle or get_spindle_overide commands executed
I tried it with a VM and sim config, as well as with a real CNC (PrintNC) on a Pi5, same behaviour.
I installed a recent dev version (github.com/LinuxCNC/linuxcnc/actions/runs/32728344015), and the linuxcncrsh coming with it works as expected. Since this dev version appeared to be a 2.10 pre-release, if the release of 2.10 is in the near future, I can live with using this dev version, don't see the need for opening an issue for 2.9.
- User Interfaces
Time to create page: 0.071 seconds
