LCNC-Cyclo: Conversational Programming for LinuxCNC
- Sviper
- Thank you received: 12
15 Nov 2026 00:41 - 15 Nov 2026 00:44 #350701
by Sviper
I'm currently working on LCNC-Cyclo, a shop-floor-oriented user interface for LinuxCNC. The idea: anyone who works with conversational-programming controls at their job should be able to work the same way on their own LinuxCNC mill at home. You write the program in conversational format, call a cycle, fill in the parameters in a form, and you're done.What already works:
LCNC-Cyclo: Conversational Programming for LinuxCNC was created by Sviper
- All screen areas and operating modes you'd expect from a shop-floor control, light/dark theme
- 58 cycles: drilling, threading, pockets, SL/contour pockets, engraving … each with an input form and help graphic
- Conversational code is translated live into real LinuxCNC G-code, with a switchable view
- PLANE functions using LinuxCNC's tilted work plane (G68.2)
- Simulation with toolpath lines, material removal, full machine model and target/actual comparison against STL
- Checks for limit switches, rapid moves in material, holder collisions and head/table collisions
- Sim machines: 4-axis XYZ+B swivel head (my Slayer_1000) and 5-axis XYZAC
Important: Unmodified LinuxCNC runs underneath. Only G-code is executed on the machine. No third-party software or data is included. The goal is simply to make operation easier for everyone who is used to conversational programming.Next steps: First use on the real machine (EtherCAT, lean system that boots directly into the GUI) and connecting an original matrix keyboard via Arduino.Feedback and ideas are welcome!
There's still a lot to do, test and expand before this becomes a full-featured GUI, but the first tests on the machine look good.The screenshots are numbered in the order they appear in the text:- Cycle with input form
- G-code view
- Material removal simulation
- Machine simulation
- Programming run → Program run
Last edit: 15 Nov 2026 00:44 by Sviper.
The following user(s) said Thank You: 0x2102, elizacommunities
- Miti
15 Nov 2026 12:04 #350728
by Miti
Replied by Miti on topic LCNC-Cyclo: Conversational Programming for LinuxCNC
first of all, great job on this! The interface looks really clean and well thought out. I’ve actually been looking for a UI like this for LinuxCNC for quite a while, especially one that brings that familiar shop-floor workflow (like Heidenhain) to an unmodified LinuxCNC setup without hiding the underlying G-code.
I have a few technical questions about the project:
Best regards
- Tech stack: What framework or toolkit is LCNC-Cyclo built on (e.g., Python/PyQt, QtVCP, QML, or something standalone communicating via the LinuxCNC Python interface)?
- Testing: Is there already a way to test an early version, or do you plan on looking for beta testers once you've finished your initial tests on the real machine?
- Open Source: Do you plan to publish the repository and make the project open source later on?
Best regards
Time to create page: 0.114 seconds
