- Thank you received: 93
Da isst der Code dazu: io.hat...
Signal 'lampe' can not add OUT pin 'pyvcp.button_lampe', it already has OUT pin 'motion.digital-out-00'
Code:# in net lampe or2.2.in0 <= motion.digital-out-00 net lampe or2.2.in1 <= pyvcp.button_lampe # out net lampe or2.2.out => hm2_7i95.0.ssr.00.out-00 <=> pyvcp.led-lampe
Fehler: Signal 'lampe' can not add OUT pin 'pyvcp.button_lampe', it already hat OUT pin 'motion.digital-out-00'
linuxcnc.org/docs/2.8/html/man/man9/toggle.9.html
Code:# Lampe net lampe_G-CODE xor2.2.in0 <= motion.digital-out-00 net lampe_button toggle.0.in <= pyvcp.button_lampe net lampe_toggle toggle.0.out xor2.2.in1 net lampe_Mesa xor2.2.out => hm2_7i95.0.ssr.00.out-00 <=> pyvcp.led-lampe Im hal loadrt toggle addf toggle.0 servo-period - das ist auf dem kopf, hab keine LinuxCNC zur zeit.
