- Thank you received: 93
P3! is a 2 pin 3.5 MM pluggable terminal block, 1 x 2-pins.
TB1 is a 24 pin 3.5 MM pluggable terminal block, 3 x 8-pins.
TB2 is a 24 pin 3.5 MM pluggable terminal block, 3 x 8-pins.
TB3 is a 24 pin 3.5 MM pluggable terminal block, 4 x 6-pins.
TB4 is a 24 pin 3.5 MM pluggable terminal block, 4 x 6-pins.
TB5 is a 24 pin 3.5 MM pluggable terminal block, 4 x 6-pins.
TB6 is a 24 pin 3.5 MM pluggable terminal block, 4 x 6-pins.
