- Thank you received: 10
Watchdog-Fehler beim Programmstart?
- Holzwurm56
- Topic Author
2 months 4 days ago #349136
by Holzwurm56
Watchdog-Fehler beim Programmstart? was created by Holzwurm56
Hallo,
wenn ich Lcnc starte kommt irgendwann die Meldung:
"hm2/hm2_7i96.0: set the.has-bit pin to False to resume"
Was könnte man da Machen? Ich benutze Axis und die Mesa 7I96, Maschinenart = Drehmaschine.
MfG
Hans
MfG
Hans
2 months 4 days ago #349140
Replied by tommylight on topic Watchdog-Fehler beim Programmstart?
Die ganze fehler, bitte.
- Thank you received: 5334
2 months 4 days ago #349141
Replied by PCW on topic Watchdog-Fehler beim Programmstart?
Typically a watchdog failure indicates a real time issue with the host computer.
What is the result of:
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
This should run 1 minute and then print out timing statistics
(replace the 10.10.10.10 with 192.168.1.121 if your 7I96 is jumpered that way))
- Holzwurm56
- Topic Author
2 months 2 days ago #349181
by Holzwurm56
Replied by Holzwurm56 on topic Watchdog-Fehler beim Programmstart?
Ich habe den Befehl eingegeben, es macht aber nur einen Durchlauf. Es kommt diese Meldung:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data
--- 10.10.10.10 ping statistics ---
6000 packets transmitted, 6000 received, 0% packet loss, time 6010ms
rtt min/arg/max/mdev = 0.059/0.069/0.174/0.004ms
2 months 2 days ago #349182
That looks OK, but I would go longer, that's why I suggested 60000 (= 1 minute)
- Holzwurm56
- Topic Author
2 months 2 days ago #349183
by Holzwurm56
Hallo, da habe ich eine Null vergessen.
60000 packets transmitted, 60000 received, 0% packet loss, time 60110ms
rtt min/arg/max/mdev = 0.055/0.071/0.181/0.004ms
2 months 2 days ago #349184
OK that sounds.
Not sure why you are getting the watchdog bite
What is the host computer, and have all power saving option been disabled in the BIOS?
Moderators: Muecke
Time to create page: 0.056 seconds
