- Thank you received: 139
Toolchanger HAL Component project
- smc.collins
- Topic Author
3 years 9 months ago - 3 years 9 months ago #260861
by smc.collins
Toolchanger HAL Component project was created by smc.collins
I am designing a new hal component dedicated specifically to control the carousel or belt style tool changers. My first draft is below, it will have significant modifications made to it shortly.
Problems this is attempting to solve;
1. configuring toolchangers with current hal components, is a big pain in the ass
2. the configuration process is difficult and buggy, multiple places for failures and errors
3. the current solutions available all require a lot of hoop jumping, working in multiple languages and dealing with lots of hal pins and files
Goals and Solutions:
1. design a flexible block execution, stair case logic motion control routine
2. include popular most popular position decoding needs
3. include jog function with forward and reverse
4. include homing feature
5. make design exestensible
Issues:
1. the real time API is difficult to work with
2. I have to focus my efforts on making my machine work, but I can post my work here for others to contribute of make derivative work
3. community engagement is very low in hard projects for the most part, and this is one of the biggest obstacles to refits
Aspirations:
having a generic flexible toolchanger component for carousel and belt tool changers will improve the acess to EMC2 in general. This will likely reduce people bailing out and also help reduce the support work load on the community forum and free up man power for solving other problems. Like redesigning the RTapi in a more sane multithreaded way that uses a watchdog execution system and allows for worker threads. So that the code complexity can be reduced by using while loops etc or brining halcompile to the world or rust or c++ or a million other things that could be getting done that aren't because many of the people who can do them are burnt out or tied up answering the same questions on the forums etc.
Also reduce new user frustration greatly. This is not going to be a easy project, and I expect at least 40 days of really hard mid night oil burning to get a basic component program working. But I will start a github page and post a link tomorrow when I have a few hours to setup git.
What can you do, well, you can post up pictures and document how your toolchanger works mechanically and electrically. this is very important knowledge, the more info at the begging of this process, the easier it will be to create a more universal toolchanger component. It may end up that derivatives of this component will need to be made, but trying to cover 80% of machines first go is the broad goal but I will settle for my machine working and as many as I can make work in the meantime.
Have a great weekend, and peace out
Issues:
Aspirations:
Last edit: 3 years 9 months ago by smc.collins.
- smc.collins
- Topic Author
3 years 9 months ago - 3 years 9 months ago #260972
by smc.collins
Replied by smc.collins on topic Toolchanger HAL Component project
could someone update the thread topic please !
The following user(s) said Thank You: billykid
- smc.collins
- Topic Author
3 years 9 months ago #261305
by smc.collins
I hope a moderator renames this thread. if anyone is wondering I HATE underscores, they are awkward to type and I find them obnoxious to deal with later in the code particularly in the hal file pin naming, Camel Case Is More Natural To Type and you follow each instance with a Number it is easier to read and type. I will be using the Haiku Operating system coding guidelines for the most part, I find them functional and easy to read, but deviate where I feel it necassary or convenient for me.
This VariableIsEasyToName1
Step 1. design a block of reusable code, that does 4 basic things
1. read a input, compares values and commands an output,
2. can error check itself in multiple ways
3. can be accurately sequenced
4. is inexpensive to execute we have time deadlines to meet.
here is that block
1. need a timer to control the pac of the executions for some outputs
param rw float FunctionTimer0 = 0.0 " variable for timer control";
pin in float FunctionTimer0Value = 1.00 in seconds;
2. we need a watchdog to ensure the execution doesn't take to long
param rw float WatchDogTimer0 = 0.0 " variable for timer control";
3. we need a execution system to control code flow. as we enter the next block in Count2, we will set the True to False and clear the execution block from falling through as is SO problematic with execution loop.
pin out bit Count1 = false;
then we end up with this code block here with the above control variables in the hal component, this is the turret unlock routine out of my Cincinnati Lathe turret component. The plan is to refactor this into a generic block that cane be configured in the hal file. The question I have is, what are the most common types of tool changer configurations ? how many steps are there in each direction to and from the storage magazine to the spindle and back ? I am thinking I might just set this up with 10 blocks in each direction ?? I think that should cover it and then make the variables for the block numbers accessible in the hal file.
If anyone has a better alternative approach to this, lmk, I am open to idea and the code is kinda in a very amorphous state.
There is a lot happening in this block of code, execution control flags, error flags, diagnostic timeouts and messages etc. This prototype will serve as the basis for constructing the Toolchanger.comp file and program. unless someone has a better idea. The parts of other components like carousel etc could be integrated into this to reduce more hal wiring, which IMHO is a good idea. Better to debug in one place then 100
if (count1 == true){ // unlock and count1 start this timer
timer0 += fperiod; // timer is incremented by fperoid
count2_5 = true; // start timer for turret watchdog
if (timer0 > unlockpause && toolchanger == true){ // 1 second unlock pause
count2 = true; // move flow control forward
count1 = false; // flow control rest at start of routine
timer0 = 0; // clear timer to clean up
// turret unlock time watchdog system make sure turret unlocks in reasonable amount of time
if (count2_5 == true && unlock == true ){ // unlock and count2 start this timer
timer1 += fperiod; // timer is incremented by fperoid
else{
if (timer1 > unlocktimeout && unlock == true){ // if timer1 is greater then unlocktimeout setting and toolchange is true
count2_5 = true; // flow control rest at start of routine
if (timer1 < unlocktimeout && unlock == true){
count3 = true;
if (count2_5 == true && timer1 > unlocktimeout) { // just changing the timer name, becuase memory leaks
unlock = false; // disable motor
toolchanger = false; // top toolchange code flow
count100 = true; // set this error flag
estop = true; // disable machine
count2_5 = false; // cancel timer
if (set_warn_flag12 == false){ // block repetitive error messages they are annoying and flood the system
rtapi_print_msg(RTAPI_MSG_ERR, "Fault 010 TURRET TOOK TO LONG TO UNLOCK EXCEEDED ESTOP ON TOOLCHANGER DISABLED");
set_warn_flag12 = true; // set flag to block prinint excesive error messages
counterT = 105; // diagnostic counter if the program hang use this in halscope to capture the value when it does, at least you got a shot
} // diagnosing the problem
here is that block
else{
count3 = true;
3 years 9 months ago #261321
Dedicated Hurco carousel component BMC SLV 80-90s vintage maybe others
Replied by tommylight on topic Toolchanger HAL Component project
Gladly, to what? This:I hope a moderator renames this thread.
The following user(s) said Thank You: smc.collins
- smc.collins
- Topic Author
3 years 9 months ago #261379
by smc.collins
Toolchanger HAL Component project, to more accurately reflect what the goal here is
3 years 9 months ago #261395
Done,
Thank you.
Thank you.
Time to create page: 0.057 seconds
