Upcoming Maintenance
Our forum will shut down for server migration on Saturday, 11/21/2026 at 05:00 CST (UTC-6).
This banner can be dismissed by pressing the X in the upper right corner.
needed this for my machine, figured I would share, you can adjust the timer for the off period and for the solenoid on period, will cycle endlessly as long as the the LubeOn pin is fed from the Lube command from hal. install with hal cmd or build with halcompile
attached correct hal file, my timer for my oiler is really long, adjust accordingly.
