Tool Changer
14 years 1 week ago #25660 by ArcEye
Replied by ArcEye on topic Re:Tool Changer
A little grepping in the source finds this code that triggered the "Unknown command" error is in src/hal/utils/halcmd.c:
That code is part of the command line parsing from halcmd, seems unlikely.
There are some others, if you do a case insensitive search, but equally unlikely.
I wonder if it isn't just a BabelFish, German to English translation thing?
Anyway can't do anything else without the configs, your code works fine, there is something else in the mix.
14 years 1 week ago #25675 by BigJohnT
Replied by BigJohnT on topic Re:Tool Changer
I did a case sensitive search to find the exact one with the "C" as you found out the case insensitive search brings up other hits.
14 years 1 week ago #25676 by andypugh
Replied by andypugh on topic Re:Tool Changer
I wouldn't be surprised to find that all HAL commands go through halcmd.
Why have two HAL parsers?
14 years 1 week ago - 14 years 1 week ago #25680 by ArcEye
I had thought of that but could not find any calls to halcmd within the /src except from minor uses by halsh.c and halmodule.cc
The function parse_cmd1(..) in which this error message occurs, is only referenced inside halcmd.c.
halcmd_parse_line(..) which uses parse_cmd1() looks a likely candidate, but is also only referenced inside halcmd.
The source code is a spaghetti bush, but I haven't found a strand which leads there yet :blink:
Last edit: 14 years 1 week ago by ArcEye.
Time to create page: 0.301 seconds
