oh my bad ,...
sorry it seems standing freehand at the machine (no internet there ) i made an typo
But i corrected it and now it should be exact as your example ,..
But linuxcnc is still not happy unknown command ? (so i milled the pcbs "manually" using the atc ... so the scripts and rest setup works fine.
Error Reads like this
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.1
Machine configuration directory is '/home/tkamsker/linuxcnc/configs/Heiz400T-3WZW'
Machine configuration file is 'Heiz400T-3WZW.ini'
INIFILE=/home/tkamsker/linuxcnc/configs/Heiz400T-3WZW/Heiz400T-3WZW.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=1834
Killing task milltask, PID=1881
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
custom_postgui.hal:4: Unknown command 'net tool-1 halui.mdi-command-00 <= pyvcp.tool-1'
1834
PID TTY STAT TIME COMMAND
1881
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 667.102407] I-pipe: Domain RTAI registered.
[ 667.102420] RTAI[hal]:
.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 667.102423] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 667.102432] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 667.102435] PIPELINE layers:
[ 667.102439] f9165e20 9ac15d93 RTAI 200
[ 667.102443] c085cb20 0 Linux 100
[ 667.131743] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 667.131959] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 667.131967] RTAI[sched]: hard timer type/freq = APIC/8311960(Hz); default timing: periodic; linear timed lists.
[ 667.131971] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2925916000 hz.
[ 667.131975] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 667.132168] RTAI[usi]: enabled.
[ 667.263218] RTAI[math]: loaded.
[ 667.373495] config string '0x378 out '
[ 673.272798] RTAI[math]: unloaded.
[ 673.372537] SCHED releases registered named ALIEN RTGLBH
[ 673.389231] RTAI[malloc]: unloaded.
[ 673.488040] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 673.493095] I-pipe: Domain RTAI unregistered.
[ 673.493108] RTAI[hal]: unmounted.
So any hint would be nice or an link to an how to
thx in advance
thomas
Ps: I do have a working pendant using arduino ,... so if someone is interested ,.. (it is work in progress )
