John:
This is great if I could just get it to work. I'm a bit confused with the component name both you and Michael (in his example) are using.
The
loadusr command wants a component name after the
-Wn flag. You are using the component name
'winder' and I'm not sure where that name came from. My gladevcp panel uses an extension of
.glade instead of
.ui. So, I'm not sure what component name to use after the
-Wn flag. Do you just create an empty file with the extension
.ui and give it a random name?
Here is the loadusr Halcmd I'm currently using:
#Loads gladevcp then python handler file and then creates glade panel
loadusr -Wn gladevcp gladevcp -c gladevcp -u handler.py wd.glade
I've tried using
gladevcp as the name after the
waitusr command, but that just locks up the terminal. I've attached my .hal file if that helps.
I actually did try playing with the
waitusr command last week, but couldn't understand what
name it wants as an argument.
File Name:
start.hal
File Size:2 KB
