Run GladeVCP from halrun
14 years 2 months ago - 14 years 2 months ago #23332 by BigJohnT
mhaberler wrote:
the spinbutton widget is a bit awkward to get right in glade, which is why there is an example in configs/gladevcp/by-widget/spinbutton .
- Michael
I don't see that directory when I use the installed 2.5 config picker from the menu... but I see them in the git repo. There must be some kind of bug in the config picker.
Last edit: 14 years 2 months ago by BigJohnT.
  • mhaberler
  • New Member
  • New Member
14 years 2 months ago #23335 by mhaberler
Replied by mhaberler on topic Re:Run GladeVCP from halrun
wd5jwy wrote:
Also, I think I found a typo in the python file:
I think that should be "widget" instead of "wedget". I'll change that, but it seemed to run ok as is. I'm gonna play with this tonight and tomorrow and see what I can do with it.
I think BigJohnT was already focusing on lunch, so it is kindof natural potato wedges get in the way.
-m
  • mhaberler
  • New Member
  • New Member
14 years 2 months ago #23336 by mhaberler
BigJohnT wrote:
- Michael
I have no good understanding what the config picker does, but at least configs/gladevcp/by-widget/spinbutton is in 2.5
probably the stuff under configs/gladevcp needs to be separated into examples and pickable configs.
Many moons ago I have proposed an example directory, but the timeout on my idea suggested the consensus opinion is "example directories are for whimps" , so that's where it wound up.
-m
14 years 2 months ago #23338 by andypugh
Perhaps you should take the approach that any suggestion which is not actively veto-ed is accepted? :-)
14 years 2 months ago #23352 by wd5jwy
Replied by wd5jwy on topic Re:Run GladeVCP from halrun
If you look in the first Glade/Python tutorial at the destroy part and add the hal unload that should take care of that part.
Yes, I thought of trying that late last night - will try it later today.
net spool-step parport.0.pin-02-out <= stepgen.0.step
I can't find "spool-step" anywhere in the docs. Is this information documented anywhere? The Hal manual doesn't address the "parport" in any detail. The naming convention is there, but no examples. I'll go look in the Integrator Manual and see what I can find.
14 years 2 months ago #23357 by BigJohnT
The Integrator manual has the parallel port driver in it. A signal name can be almost anything you like... see this chapter from the Hal Manual.
Moderators: HansU
Time to create page: 0.065 seconds
