Glade 3.8.5 and LinuxCNC RIP build: how to install the catalog?
9 years 10 months ago #83600 by cmorley
on my wheezy distro the command is glade-gtk2...
The erorr messages while odd don't seem to give much clue unfortunately
Chris M
9 years 10 months ago #83602 by tommylight
9 years 10 months ago #83603 by cmorley
No current linuxcnc parts require gnome widgets.
Chris M
9 years 10 months ago #83706 by islander261
Hello
I really don't know much about using Linux. I am running LMDE-2 and want to reinstall ( compile) Glade 3.8.5 now that I have all the widgets and parts in the correct locations. Do I need to remove the current installation? If so is there higher level GUI supported method or do I just manually remove directories and files?
9 years 10 months ago - 9 years 10 months ago #83719 by islander261
Hello
I just want to report that I finally got all the HAL widgets to work with my Glade 3.8.5 install. In addition to doing this:
You need to copy all files from linuxcnc-dev/lib/python/gladevcp to /usr/lib/pymodules/python2.7/gladevcp and /usr/share/pyshared/gladevcp
I also needed to do this:
sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.xml usr/local/share/glade3/catalogs
As well as:
[sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.png usr/local/share/glade3/pixmaps
I still can't start Glade from the terminal with the glade-gtk2 command but glade-3 works for now.
Last edit: 9 years 10 months ago by islander261. Reason: fix formating
The following user(s) said Thank You: kpj10
8 years 5 months ago #110231 by kpj10
Add the LinuxCNC stuff to the GLADE_CATALOG_SEARCH_PATH: export GLADE_CATALOG_SEARCH_PATH=~/linuxcnc-dev/lib/python/gladevcp
I didn't get where to put this. I'm using Ubuntu 14.04, simulation installation.
I tried writing this in my /etc/environment file but still there is catalogue not found error.
Hope for your help,
Thank you
Kunal.
Moderators: HansU
Time to create page: 0.103 seconds
