Glade project scaling to box size
- The Feral Engineer
- Thank you received: 23
15 Dec 2020 01:14 - 15 Dec 2020 01:15 #192010
by The Feral Engineer
Glade project scaling to box size was created by The Feral Engineer
I'm using gmoccapy and trying to embed a small window with 2 leds, a button and a label. I have them sized the way I want in glade, but they stretch out all crazy when I load them into gmoccapy and haven't figured out how to lock them to the size i have in my glade project
Beginner's question, i know. Just started messing with glade last night.
Last edit: 15 Dec 2020 01:15 by The Feral Engineer.
- Thank you received: 2181
15 Dec 2020 01:20 #192014
Replied by cmorley on topic Glade project scaling to box size
you may have set the sizes in GLADE on the main window.
When embedded the main window is replaced. try setting the sizes on the widgets just inside the main window.
15 Dec 2020 01:22 #192015
I might add - i'm kinda guessing because you have not given code or sample pics for reference.
The following user(s) said Thank You: The Feral Engineer
15 Dec 2020 01:24 #192018
Replied by The Feral Engineer on topic Glade project scaling to box size
That did the trick. Had to size my table, not the main Thanks!
15 Dec 2020 01:31 #192020
Okay, did half the trick. Height is still stretching
Moderators: HansU
Time to create page: 0.266 seconds
