I want to use a signal to control the emergency stop. How should I start?
- yi2580
- Thank you received: 3
18 Aug 2021 02:48 #218034
by yi2580
I want to use a signal to control the emergency stop. How should I start? was created by yi2580
Now I want to connect a sensor on the shaft. If the sensor sends a corresponding signal, it can realize automatic emergency stop or operation. What should I do?
Can anyone help me, thank you
- Thank you received: 4152
18 Aug 2021 08:09 #218047
Replied by rodw on topic I want to use a signal to control the emergency stop. How should I start?
You can use estop-latch to daisy chain multiple estops in software.
There is an example hereĀ forum.linuxcnc.org/47-hal-examples/25861-external-e-stop
But this may not be a compliant safety system
- yi2580
18 Aug 2021 09:43 #218060
by yi2580
Replied by yi2580 on topic I want to use a signal to control the emergency stop. How should I start?
OK, thank you very much for your guidance. I'll try your method
Thank you again
Thank you again
Moderators: HansU
Time to create page: 0.215 seconds
