Setting Hal parameters
- slammers
16 Oct 2021 04:43 #223277
by slammers
Setting Hal parameters was created by slammers
I would like to change a Hal components parameter through a Python script in my Glade VCP. Is this possible?
I would like to change one of my Mesa stepgen scale parameters and since you can not connect a signal to a parameter (as far as I know) I have been struggling on how to do this. My workaround has been to add a scale component to the stepgen velocity input and connect a signal to its gain pin. But I would rather change the stepgen scale parameter directly.
- Thank you received: 2181
16 Oct 2021 07:19 #223281
Replied by cmorley on topic Setting Hal parameters
Yes, using the HAL python module's function set_p you should be able to do that.
linuxcnc.org/docs/2.8/html/hal/halmodule.html#_set_p
Moderators: HansU
Time to create page: 0.073 seconds
