master 2.9 + glade no linuxcnc widgets / tools loading?
4 years 3 months ago #248696 by andypugh
Are you sure that you are not just overlooking the widgets? They are hidden under the three dots (at least with the 3.22.1 that I am using)
4 years 6 days ago #255135 by thadwald
I am having the same issue; none of the Linuxcnc widgets show up under the toolbox.
My setup is running Debian 9 from the 2.8 ISO with Linuxcnc version changed to master by changing the repositories.
I tried copying the contents from /usr/share/glade3 to /usr/share/glade. Now I see the appropriate categories or type placeholders in the toolbox, but no widgets.
4 years 6 days ago #255136 by thadwald
running glade from command line shows the following errors:
(glade:13834): GladeUI-WARNING **: 16:27:48.164: We could not find the symbol "h_al__hide_table_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Could not get the type from "HAL_HideTable" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Failed to load the GType for 'HAL_HideTable' (glade:13834): GladeUI-WARNING **: 16:27:48.164: We could not find the symbol "h_al__hbox_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Could not get the type from "HAL_HBox" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Failed to load the GType for 'HAL_HBox' (glade:13834): GladeUI-WARNING **: 16:27:48.164: We could not find the symbol "h_al__table_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Could not get the type from "HAL_Table" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Failed to load the GType for 'HAL_Table' (glade:13834): GladeUI-WARNING **: 16:27:48.164: We could not find the symbol "state__sensitive__table_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Could not get the type from "State_Sensitive_Table" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Failed to load the GType for 'State_Sensitive_Table' (glade:13834): GladeUI-WARNING **: 16:27:48.164: We could not find the symbol "h_al__combo_box_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Could not get the type from "HAL_ComboBox" (glade:13834): GladeUI-WARNING **: 16:27:48.164: Failed to load the GType for 'HAL_ComboBox' (glade:13834): GladeUI-WARNING **: 16:27:48.164: We could not find the symbol "h_al__button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.165: Could not get the type from "HAL_Button" (glade:13834): GladeUI-WARNING **: 16:27:48.165: Failed to load the GType for 'HAL_Button' (glade:13834): GladeUI-WARNING **: 16:27:48.165: We could not find the symbol "h_ali_o__button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.165: Could not get the type from "HALIO_Button" (glade:13834): GladeUI-WARNING **: 16:27:48.165: Failed to load the GType for 'HALIO_Button' (glade:13834): GladeUI-WARNING **: 16:27:48.165: We could not find the symbol "h_al__check_button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.170: Could not get the type from "HAL_CheckButton" (glade:13834): GladeUI-WARNING **: 16:27:48.170: Failed to load the GType for 'HAL_CheckButton' (glade:13834): GladeUI-WARNING **: 16:27:48.170: We could not find the symbol "h_al__spin_button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.170: Could not get the type from "HAL_SpinButton" (glade:13834): GladeUI-WARNING **: 16:27:48.170: Failed to load the GType for 'HAL_SpinButton' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_al__toggle_button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Could not get the type from "HAL_ToggleButton" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Failed to load the GType for 'HAL_ToggleButton' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_al__radio_button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Could not get the type from "HAL_RadioButton" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Failed to load the GType for 'HAL_RadioButton' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_al__hscale_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Could not get the type from "HAL_HScale" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Failed to load the GType for 'HAL_HScale' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_ali_o__hscale_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Could not get the type from "HALIO_HScale" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Failed to load the GType for 'HALIO_HScale' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_al__vscale_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Could not get the type from "HAL_VScale" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Failed to load the GType for 'HAL_VScale' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_al__progress_bar_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Could not get the type from "HAL_ProgressBar" (glade:13834): GladeUI-WARNING **: 16:27:48.171: Failed to load the GType for 'HAL_ProgressBar' (glade:13834): GladeUI-WARNING **: 16:27:48.171: We could not find the symbol "h_al__light_button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "HAL_LightButton" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Failed to load the GType for 'HAL_LightButton' (glade:13834): GladeUI-WARNING **: 16:27:48.172: We could not find the symbol "h_al__le_d_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "HAL_LED" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Failed to load the GType for 'HAL_LED' (glade:13834): GladeUI-WARNING **: 16:27:48.172: We could not find the symbol "h_al__label_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "HAL_Label" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Failed to load the GType for 'HAL_Label' (glade:13834): GladeUI-WARNING **: 16:27:48.172: We could not find the symbol "status__label_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "Status_Label" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Failed to load the GType for 'Status_Label' (glade:13834): GladeUI-WARNING **: 16:27:48.172: We could not find the symbol "state__label_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "State_Label" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Failed to load the GType for 'State_Label' (glade:13834): GladeUI-WARNING **: 16:27:48.172: We could not find the symbol "h_al__hbar_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "HAL_HBar" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Failed to load the GType for 'HAL_HBar' (glade:13834): GladeUI-WARNING **: 16:27:48.172: We could not find the symbol "h_al__vbar_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.172: Could not get the type from "HAL_VBar" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'HAL_VBar' (glade:13834): GladeUI-WARNING **: 16:27:48.173: We could not find the symbol "override_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Could not get the type from "Override" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'Override' (glade:13834): GladeUI-WARNING **: 16:27:48.173: We could not find the symbol "h_al__gremlin_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Could not get the type from "HAL_Gremlin" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'HAL_Gremlin' (glade:13834): GladeUI-WARNING **: 16:27:48.173: We could not find the symbol "h_al__meter_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Could not get the type from "HAL_Meter" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'HAL_Meter' (glade:13834): GladeUI-WARNING **: 16:27:48.173: We could not find the symbol "h_al__graph_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Could not get the type from "HAL_Graph" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'HAL_Graph' (glade:13834): GladeUI-WARNING **: 16:27:48.173: We could not find the symbol "jog_wheel_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Could not get the type from "JogWheel" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'JogWheel' (glade:13834): GladeUI-WARNING **: 16:27:48.173: We could not find the symbol "speed_control_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Could not get the type from "SpeedControl" (glade:13834): GladeUI-WARNING **: 16:27:48.173: Failed to load the GType for 'SpeedControl' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "hal__dial_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "Hal_Dial" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'Hal_Dial' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "py_ngc_gui_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "PyNgcGui" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'PyNgcGui' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "h_al__gremlin_plus_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "HAL_GremlinPlus" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'HAL_GremlinPlus' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "tool_edit_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "ToolEdit" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'ToolEdit' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "offset_page_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "OffsetPage" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'OffsetPage' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "h_al__dr_o_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "HAL_DRO" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'HAL_DRO' (glade:13834): GladeUI-WARNING **: 16:27:48.174: We could not find the symbol "combi__dr_o_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Could not get the type from "Combi_DRO" (glade:13834): GladeUI-WARNING **: 16:27:48.174: Failed to load the GType for 'Combi_DRO' (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "icon_file_selection_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "IconFileSelection" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Failed to load the GType for 'IconFileSelection' (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "h_al__offset_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "HAL_Offset" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Failed to load the GType for 'HAL_Offset' (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "calculator_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "Calculator" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Failed to load the GType for 'Calculator' (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "e_mc__action__esto_p_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "EMC_Action_ESTOP" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Failed to load the GType for 'EMC_Action_ESTOP' (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "e_mc__action__esto_p__rese_t_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "EMC_Action_ESTOP_RESET" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Failed to load the GType for 'EMC_Action_ESTOP_RESET' (glade:13834): GLib-CRITICAL **: 16:27:48.175: g_string_insert_c: assertion 'pos <= string->len' failed (glade:13834): GLib-CRITICAL **: 16:27:48.175: g_string_insert_c: assertion 'pos <= string->len' failed (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "e_mc__action__on_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "EMC_Action_ON" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Failed to load the GType for 'EMC_Action_ON' (glade:13834): GladeUI-WARNING **: 16:27:48.175: We could not find the symbol "e_mc__action__of_f_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.175: Could not get the type from "EMC_Action_OFF" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_OFF' (glade:13834): GladeUI-WARNING **: 16:27:48.176: We could not find the symbol "e_mc__action__run_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Could not get the type from "EMC_Action_Run" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_Run' (glade:13834): GladeUI-WARNING **: 16:27:48.176: We could not find the symbol "e_mc__action__step_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Could not get the type from "EMC_Action_Step" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_Step' (glade:13834): GladeUI-WARNING **: 16:27:48.176: We could not find the symbol "e_mc__action__pause_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Could not get the type from "EMC_Action_Pause" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_Pause' (glade:13834): GladeUI-WARNING **: 16:27:48.176: We could not find the symbol "e_mc__action__resume_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Could not get the type from "EMC_Action_Resume" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_Resume' (glade:13834): GladeUI-WARNING **: 16:27:48.176: We could not find the symbol "e_mc__action__stop_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Could not get the type from "EMC_Action_Stop" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_Stop' (glade:13834): GladeUI-WARNING **: 16:27:48.176: We could not find the symbol "e_mc__action__md_i_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Could not get the type from "EMC_Action_MDI" (glade:13834): GladeUI-WARNING **: 16:27:48.176: Failed to load the GType for 'EMC_Action_MDI' (glade:13834): GladeUI-WARNING **: 16:27:48.177: We could not find the symbol "e_mc__action__home_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Could not get the type from "EMC_Action_Home" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Failed to load the GType for 'EMC_Action_Home' (glade:13834): GladeUI-WARNING **: 16:27:48.177: We could not find the symbol "e_mc__action__unhome_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Could not get the type from "EMC_Action_Unhome" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Failed to load the GType for 'EMC_Action_Unhome' (glade:13834): GladeUI-WARNING **: 16:27:48.177: We could not find the symbol "e_mc__action__python_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Could not get the type from "EMC_Action_Python" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Failed to load the GType for 'EMC_Action_Python' (glade:13834): GladeUI-WARNING **: 16:27:48.177: We could not find the symbol "e_mc__toggle_action__esto_p_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Could not get the type from "EMC_ToggleAction_ESTOP" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Failed to load the GType for 'EMC_ToggleAction_ESTOP' (glade:13834): GladeUI-WARNING **: 16:27:48.177: We could not find the symbol "e_mc__toggle_action__power_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Could not get the type from "EMC_ToggleAction_Power" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Failed to load the GType for 'EMC_ToggleAction_Power' (glade:13834): GladeUI-WARNING **: 16:27:48.177: We could not find the symbol "e_mc__toggle_action__run_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Could not get the type from "EMC_ToggleAction_Run" (glade:13834): GladeUI-WARNING **: 16:27:48.177: Failed to load the GType for 'EMC_ToggleAction_Run' (glade:13834): GladeUI-WARNING **: 16:27:48.178: We could not find the symbol "e_mc__toggle_action__stop_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Could not get the type from "EMC_ToggleAction_Stop" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Failed to load the GType for 'EMC_ToggleAction_Stop' (glade:13834): GladeUI-WARNING **: 16:27:48.178: We could not find the symbol "e_mc__toggle_action__pause_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Could not get the type from "EMC_ToggleAction_Pause" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Failed to load the GType for 'EMC_ToggleAction_Pause' (glade:13834): GladeUI-WARNING **: 16:27:48.178: We could not find the symbol "e_mc__toggle_action__md_i_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Could not get the type from "EMC_ToggleAction_MDI" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Failed to load the GType for 'EMC_ToggleAction_MDI' (glade:13834): GladeUI-WARNING **: 16:27:48.178: We could not find the symbol "e_mc__radio_action__esto_p_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Could not get the type from "EMC_RadioAction_ESTOP" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Failed to load the GType for 'EMC_RadioAction_ESTOP' (glade:13834): GladeUI-WARNING **: 16:27:48.178: We could not find the symbol "e_mc__radio_action__esto_p__rese_t_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Could not get the type from "EMC_RadioAction_ESTOP_RESET" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Failed to load the GType for 'EMC_RadioAction_ESTOP_RESET' (glade:13834): GladeUI-WARNING **: 16:27:48.178: We could not find the symbol "e_mc__radio_action__on_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Could not get the type from "EMC_RadioAction_ON" (glade:13834): GladeUI-WARNING **: 16:27:48.178: Failed to load the GType for 'EMC_RadioAction_ON' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__radio_action__of_f_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Could not get the type from "EMC_RadioAction_OFF" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Failed to load the GType for 'EMC_RadioAction_OFF' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__stat_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Could not get the type from "EMC_Stat" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Failed to load the GType for 'EMC_Stat' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__file_chooser_dialog_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Could not get the type from "EMC_FileChooserDialog" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Failed to load the GType for 'EMC_FileChooserDialog' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__file_chooser_button_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Could not get the type from "EMC_FileChooserButton" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Failed to load the GType for 'EMC_FileChooserButton' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__action__open_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Could not get the type from "EMC_Action_Open" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Failed to load the GType for 'EMC_Action_Open' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__action__reload_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Could not get the type from "EMC_Action_Reload" (glade:13834): GladeUI-WARNING **: 16:27:48.179: Failed to load the GType for 'EMC_Action_Reload' (glade:13834): GladeUI-WARNING **: 16:27:48.179: We could not find the symbol "e_mc__action__save_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Could not get the type from "EMC_Action_Save" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Failed to load the GType for 'EMC_Action_Save' (glade:13834): GladeUI-WARNING **: 16:27:48.180: We could not find the symbol "e_mc__action__save_as_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Could not get the type from "EMC_Action_SaveAs" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Failed to load the GType for 'EMC_Action_SaveAs' (glade:13834): GladeUI-WARNING **: 16:27:48.180: We could not find the symbol "e_mc__source_view_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Could not get the type from "EMC_SourceView" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Failed to load the GType for 'EMC_SourceView' (glade:13834): GladeUI-WARNING **: 16:27:48.180: We could not find the symbol "e_mc__mdi_history_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Could not get the type from "EMC_MDIHistory" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Failed to load the GType for 'EMC_MDIHistory' (glade:13834): GladeUI-WARNING **: 16:27:48.180: We could not find the symbol "macro_select_get_type" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Could not get the type from "MacroSelect" (glade:13834): GladeUI-WARNING **: 16:27:48.180: Failed to load the GType for 'MacroSelect' (glade:13834): GladeUI-WARNING **: 16:27:48.180: Tried to include undefined widget class 'HAL_HideTable' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.180: Tried to include undefined widget class 'HAL_Table' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.180: Tried to include undefined widget class 'State_Sensitive_Table' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_LED' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_ComboBox' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_Button' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_LightButton' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HALIO_Button' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_SpinButton' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_CheckButton' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_ToggleButton' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_RadioButton' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_HScale' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HALIO_HScale' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_VScale' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'Override' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_ProgressBar' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_Label' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'State_Label' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'Status_Label' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_HBar' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_VBar' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_Gremlin' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_Meter' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.181: Tried to include undefined widget class 'HAL_Graph' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'JogWheel' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'SpeedControl' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'Hal_Dial' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'PyNgcGui' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'HAL_GremlinPlus' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'ToolEdit' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'Calculator' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'HAL_DRO' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'Combi_DRO' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'IconFileSelection' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'HAL_Offset' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'OffsetPage' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_Stat' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_FileChooserDialog' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_FileChooserButton' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_SourceView' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_MDIHistory' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'MacroSelect' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_Action_ESTOP' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_Action_ESTOP_RESET' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.182: Tried to include undefined widget class 'EMC_Action_ON' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_OFF' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Run' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Step' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Pause' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Resume' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Stop' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_MDI' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Home' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Unhome' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_ToggleAction_ESTOP' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_ToggleAction_Power' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_ToggleAction_Run' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_ToggleAction_Stop' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_ToggleAction_Pause' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_ToggleAction_MDI' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_RadioAction_ESTOP' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_RadioAction_ESTOP_RESET' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_RadioAction_ON' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_RadioAction_OFF' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Open' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Reload' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.183: Tried to include undefined widget class 'EMC_Action_Save' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.184: Tried to include undefined widget class 'EMC_Action_SaveAs' in a widget group (glade:13834): GladeUI-WARNING **: 16:27:48.184: Tried to include undefined widget class 'EMC_Action_Python' in a widget group
4 years 5 days ago #255191 by HansU
Have you tried in a run-in-place environment?
3 years 9 months ago #262630 by ChironFZ16
It works, thanks for the suggestion image missing /media/kunena/emoticons/smile.png
3 years 4 months ago #273097 by Olumide
I am having the same problem but outside linuxcnc.
What is a run-in-place environment? Is it a version of glade, a patched version of glade? A version of glade with some special environment variables or has the class or catalogue format different?
Moderators: HansU
Time to create page: 0.063 seconds
