I seemed to have borked my GTK/Glade installation
- JetForMe
- Thank you received: 27
02 Sep 2024 20:47 - 02 Sep 2024 20:48 #309246
by JetForMe
I seemed to have borked my GTK/Glade installation was created by JetForMe
I was running a 2.9.0 prerelease and decided to upgrade to the current 2.9.3. That seemed to go smoothly, but now when I launch linuxcnc, it exits with the following. Looking at the apt upgrade transcript, it definitely installed some GTK stuff. But this is the main error:
I've struggled a lot in the past with GTK 2 vs 3 issues. I'd be happy to move to GTK 3, if Axis and LinuxCNC can handle that, but I'm not sure how it would break my VCP. I've attached some files in case they help
**** GLADE VCP ERROR: With xml file: ./lzpanel.ui : 'gi.repository.Gtk' object has no attribute 'glade'I've struggled a lot in the past with GTK 2 vs 3 issues. I'd be happy to move to GTK 3, if Axis and LinuxCNC can handle that, but I'm not sure how it would break my VCP. I've attached some files in case they help
Last edit: 02 Sep 2024 20:48 by JetForMe.
- Thank you received: 4659
05 Sep 2024 08:53 #309409
Replied by andypugh on topic I seemed to have borked my GTK/Glade installation
In the ui file it says:
interface-requires gladevcp 0.0
requires lib="gtk+" version="2.24"
Whereas the current version of the lathemacros has
<requires lib="gtk+" version="3.4"/>
<requires lib="gladevcp" version="0.0"/>
Do any of the sample gladevcp configs work?
It might help to open your .ui file in the latest glade and then re-save it.
- JetForMe
29 Apr 2025 21:42 #327326
by JetForMe
Replied by JetForMe on topic I seemed to have borked my GTK/Glade installation
I think the last time I tried to update to GTK+3, a bunch of the components no longer existed, like HAL_HideTable. Where do those come from?
02 May 2025 14:57 #327537
Anything HAL in GTK will have come with the LinuxCNC installation.
It _might_ help to install linuxcnc-uspace-dev (it won't hurt, at least)
- JetForMe
02 May 2025 21:07 #327577
by JetForMe
I finally managed to sort it out and update my .ui file to GTK+3. I wish there was a better guide for the various LinuxCNC-specific components and the migration necessary.
- richcolvin
30 Jul 2025 13:46 #332569
by richcolvin
Replied by richcolvin on topic I seemed to have borked my GTK/Glade installation
What did you do to fix it?
- JetForMe
30 Jul 2025 19:01 #332581
by JetForMe
I updated to GTK+ v3.x, and asked ChatGPT to help me update my lzpanel.ui file to the latest version. It was amazingly helpful in this regard, although I think there were a couple hiccups along the way.What did you do to fix it?
Moderators: HansU
